Replacing rear wiper blade
Old May 11, 2011 | 05:04 PM
kpdandjad's Avatar
Default Replacing rear wiper blade
I have a 2008 FEH. I was able to easily replace the front wiper blades, but the rear wiper blade has me stumped. I cannot figure our how to remove it from the wiper arm. The arm only lifts off the glass a few inches so there is not enough room to rotate the blade, like you can with the front blades. Any suggestions?
Old May 14, 2011 | 06:41 AM
RiverRat37's Avatar
Default Re: Replacing rear wiper blade
The rear wiper on mine (FEH 2006) is a shepard's crook. You simply pinch the partly exposed flat piece at the inside of the crook and slide the blade towards the wiper-pivot point. It's not esp. intuitive but it works and is easy once you "get it". I put on an 11" blade (overall measure) with some good success at clearing more of the window. It's not perfect -- it partly rides up and off the window at some points but it's an improvement.
Will someone please explain to me why windshield wiper engineers can't design a simple to understand and easy to do, wiper blade exchange?
UWAdventurer
Dec 5, 2010 12:10 PM
dburanich
Mar 12, 2010 08:12 AM
icebluemariner
May 29, 2009 10:35 AM
zimbop
Mar 26, 2009 02:55 PM
Doug
Mar 5, 2009 01:03 PM
