Tailgate glass/door ajar message, how to fix it?
Old May 20, 2011 | 08:18 PM
rperla's Avatar
Escape HEV'08 El Salvador
Default Tailgate glass/door ajar message, how to fix it?
My FEH'08 was pretty bad rear-ended...and after the repairs it's showing this message, even when everything is closed and locked...somebody knows where the switch (or connector to check) is? I cannot find any pushrod or contact switch to fix...someone can share a wiring diagram for this?
Thanks a lot!
Old May 22, 2011 | 08:58 AM
Default Re: Tailgate glass/door ajar message, how to fix it?
Look at p117-4 of the FEH Wiring diagrams. There are two switches in the circuit, one for the glass & one for the liftgate. If there is a broken wire in the circuit that would give the same indication as if the gate or glass was open.
First go look at the switches themselves and check that the wires are connected properly. They could be dirty or whatever, so pull the connectors off & reinstall them. This should punch thru any dirt.
If you have a multimeter, with the connectors disconnected, operate the switch and ensure it works. (ie opens and closes electrically)
If that doesn't work then start tracing the wires back. You're looking for some kind of a break. If you have a multimeter you can pull plugs and check for continuity progressively from plug to plug.
Old May 23, 2011 | 01:35 PM
rperla's Avatar
thank you Bill...but I don't have taht wiring diagram (I've tried to take it form Autozone's web...) could you be so kind to post it?
LEAKYTCH
Apr 7, 2013 08:56 AM
webcorrecto
Sep 10, 2009 07:51 AM
smallen13
Jul 24, 2008 06:16 AM
mikieboyblue
Sep 12, 2007 10:27 AM
rigger
Nov 27, 2005 11:19 AM
