Service Brake System warning ???
Old Sep 15, 2010 | 10:48 AM
Lone Ranger's Avatar
Default Service Brake System warning ???
The Service Brake System warning came on. Any thoughts what this might be from? I just replaced all the rotors and pads. I have a FWD '07.
If anyone has had this happened, what were the costs associated with the problem and what parts were needed?
I used the SG to scan for trouble codes and it was neg. There are no brake light warnings on the dash.
Thanks in advance.
Old Sep 15, 2010 | 03:09 PM
Default Re: Service Brake System warning ???
I brought the car to the dealership and they found the tone ring on the right side was cracked. The crack affects the ABS sensor which resulted in the stutter/skip/shudder I felt prior to doing the brakes and since doing the brakes. One more thing to look for when doing brakes. So the tone ring also, as it was explained to me, was causing the ABS to send a message to Service Brake System alert. The dealer also found codes that were set that he has no info on. I asked him to write down the codes, hopefully when I pick the veh up tomorrow he'll have them. He also mentioned that he found the error code for the Blend Door and re-flashed the puter.
I have to thank everyone that pointed me in the right direction for DTC code for the Blend Door and the TSB concerning repair. That's what makes this forum and those that post so great. The money I saved on the Blend Door install is going towards the repair of the tone ring. I figure I broke even, kind of.
These are the only problems I've had with the Escape Hybrid and hopefully the last. I'll know more tomorrow.
Previously I attributed problems to the Blend Door and worn brakes (which they were and would have needed replacement).
Old Sep 15, 2010 | 03:44 PM
econoline's Avatar
Lone Ranger, did you see the tone ring discussion at the end of this thread?
https://www.greenhybrid.com/discuss/...43/#post227515
Old Oct 31, 2010 | 09:23 AM
anish_s's Avatar
Unhappy Re: Service Brake System warning ???
Hi! Lone Ranger
Do you have any update on this issue? I have a FEH 2005 FWD and I get the same message with the brake warning light i.e. the red icon on the dashboard. I do not see any ABS messages and nor do I notice any problems with braking.
The brakes were serviced in September and it cost me an additional $90 just to have a Ford dealer inspect them and supposedly "Reset the Computer". The mech. said that there were no error codes with the ABS system and everything was fine.
But, yesterday while driving I received the same message
Please help
Anish
Old Oct 31, 2010 | 11:46 AM
travelover's Avatar
Feral Engineer
Originally Posted by anish_s
Please help
Anish
The tone ring can crack at any time. You can inspect it yourself. It is behind the brake shield and just outboard of the CV joint. It looks like a gear about 3 inches in diameter. It may even be loose - it you can rotate it, it is broken.
Old Oct 31, 2010 | 01:14 PM
anish_s's Avatar
Thumbs up Re: Service Brake System warning ???
Thanks Travelover.....I will check my tone rings...
So, assuming that the tone ring is cracked/broken....is it safe to drive?
I have about 94,000kms (60,000 miles) approx
Regards
Anish
Originally Posted by travelover
The tone ring can crack at any time. You can inspect it yourself. It is behind the brake shield and just outboard of the CV joint. It looks like a gear about 3 inches in diameter. It may even been loose - it you can rotate it, it is broken.
Old Nov 4, 2010 | 08:45 AM
travelover's Avatar
Feral Engineer
Regards
Anish
You will have brakes, but the ABS won't work properly.
Defender
190
Feb 18, 2021 06:05 PM
EOppie
Apr 23, 2019 06:21 AM
anish_s
May 3, 2011 08:31 AM
<ivi>
Jun 5, 2007 08:23 AM
