2009 escape hybrid ev motor seems to work but gas engine not starting
Old Oct 9, 2023 | 10:06 AM
autobahn's Avatar
Default 2009 escape hybrid ev motor seems to work but gas engine not starting
long time lurker I've had great success from this site over the last few years. a big thanks to S Keith as it always seems he has all the knowledge. This particular escape came in with a low ev battery and wouldn't do anything. We instantly went to work and disassembled the battery cover and put our charger we built with Keith's instructions on here to work. After getting the battery up to snuff we reconnected everything and attempted to start the vehicle. It appears that the electric motor turns on you can hear it running it will do this for a minute or so and you can even attempt to drive around the parking lot before the red triangle pops up and cuts the electric motor off. this can be done over and over as long as you cycle the key. The gas engine never starts though. the following codes in forscan after an attempt are as follows.
pcm
P0c2f:00-2b engine speed sensor performance
tcm
p0727-ff
i replaced the crank sensor to no avail any input on what to maybe try next or if im missing something i thank you in advance.
Old Oct 9, 2023 | 06:53 PM
Default Re: 2009 escape hybrid ev motor seems to work but gas engine not starting
Disconnect the fuel line from the injector rail and confirm you are getting fuel at the rail. I had to replace the fuel pump in my '05... twice.
Old Oct 11, 2023 | 02:57 PM
autobahn's Avatar
verified fuel at rail and used pressure tester shows within spec.
Old Oct 11, 2023 | 05:16 PM
https://www.motorcraftservice.com
You can get full access to manuals for something like $25.
escapehybrid
May 9, 2022 03:13 PM
TNZllc
Jun 9, 2021 03:17 PM
rmpowell2001
Oct 25, 2019 10:46 PM
