09 FEH car sit only 2 days, won't start
Old May 13, 2022 | 10:17 PM
accent2010's Avatar
Default 09 FEH car sit only 2 days, won't start
It's super worm in Dallas recently. This car sit for about 2 days then won't start any more. It actually started but only 10 second it would die. After 10 minutes waiting and started it again, and it would do another 10 seconds then die thing again. Then the battery has no juice to start and the stop safely error showed up. I don't see things like fuel pump error in the DTC. Any idea? Here is the full list of the codes. Thank you in advance!
===PCM DTC P0A1F:00-AC===
Code: P0A1F - Battery Energy Control Module A Performance
Status:
- DTC Maturing - Intermittent at Time of Request
- Malfunction Indicator Lamp is On for this DTC
Module: Powertrain Control Module
===END PCM===
===PCM DTC P1A10:00-2B===
Code: P1A10 - Hybrid Powertrain Control Module - Battery Disabled
Status:
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
===END PCM===
===OBDII DTC P0A1F-C===
Status:
- Confirmed - malfunction is confirmed
Module: On Board Diagnostic II
===END OBDII===
===ABS DTC U3003:16-60===
Code: U3003 - Battery Voltage
Additional Fault Symptom:
- Circuit Voltage Below Threshold
Status:
- Test not complete
Module: Antilock braking system
Freeze Frame #1:
-OUTDOOR_TEMPERATURE: -35 °C - Outside temperature
-ABS: Inactive - ABS
-AYC: Inactive - AYC
-BTCS: Inactive - BTCS -201D
-HDC: Inactive - HDC
-RSC: Inactive - RSC
-BTC: Inactive - BTC
-VAC_BST_ST: Inactive - Active Vacuum Booster State
-BST_REL_SW: Inactive - Booster Release Switch State
-HYD_PMP_ST: Inactive - Hydraulic Pump State
-ECU_POWER_SUPPLY: 9.3 V - ECU Power Supply Voltage
-VSS: 0.0 km/h - Vehicle Speed
===END ABS===
===ABS DTC C1018:00-28===
Code: C1018 - Regenerative Braking
Status:
- Previously Set DTC - Not Present at Time of Request
Freeze Frame #1:
-OUTDOOR_TEMPERATURE: -11 °C - Outside temperature
-ECU_POWER_SUPPLY: 12.0 V - ECU Power Supply Voltage
===END ABS===
===RCM DTC U0253:00-0B===
Code: U0253 - Lost Communication With Accessory Protocol Interface Module
Status:
Module: Restraint Control Module
===END RCM===
===TCM DTC P1A07-FF===
Code: P1A07 - Inverter High Voltage Performance
Module: Transmission Control Module
===END TCM===
===OCS DTC ===
Successful DTC reading, no error codes found
Module: Occupant Classification System Module
===END OCS===
===BCM DTC P0A7D-60===
Code: P0A7D - Hybrid Battery Pack State of Charge Low
Status:
Module: Battery Control Module
===END BCM===
===BCM DTC P0A1F-60===
Status:
===END BCM===
===PSCM DTC ===
Module: Power Steering Control Module
===END PSCM===
===IC DTC U2511-20===
Code: U2511 - CAN communication bus fault
Status:
Module: Instrument Cluster
===END IC===
Old May 14, 2022 | 07:06 AM
ShadyEscape's Avatar
Default Re: 09 FEH car sit only 2 days, won't start
It has been hot, does your A/C work? It says up there regenerative braking was disabled too? Maybe you've been using the car and it hasn't been recharging the battery.
You did get 2 starts. Something else is wrong where the car won't keep running. Check you're actually getting fuel and spark.
The way to see if it is the battery would be charging it and seeing how much voltage drops overnight.
accent2010
Feb 17, 2023 02:40 PM
2008 Prius
Jun 25, 2021 06:14 AM
accent2010
Feb 22, 2021 03:15 PM
runchadrun
Jun 6, 2007 07:46 AM
JOE540CI
Toyota Highlander Hybrid
Oct 24, 2005 06:30 AM
