Letting Prius Sit for Long Periods
Old Jun 24, 2021 | 12:04 PM
2008 Prius's Avatar
Default Letting Prius Sit for Long Periods
Newb here...
Daughter moved to NYC and took our '08 Prius. She uses the car once a week at best. Often just to move to a new parking spot.
Anyway, today, the battery was dead. Bought a new battery and Toyota dealer told her driving once a week was not sufficient and to expect the battery to die often. Now wondering if her driving habits make sense to own a Prius?
Can it sit for a week at a time, then only get driven for 30-40 minutes - once a week?
Other than this dead battery, the car has been flawless. The most reliable car I've ever owned - hands down.
Thanks for your advice.
Old Jun 24, 2021 | 12:20 PM
Default Re: Letting Prius Sit for Long Periods
Originally Posted by 2008 Prius
Newb here...
The dealer is correct. Why drive a hybrid if you're not going to drive and get the benefits while carrying the risk of the additional failure potentials?
I recommend 3 drives/week minimum for 10 miles each or 20-30 minutes each, BUT 500 minimum miles per month, meaning there will be some extended drives sprinkled in there.
Disabling the smartkey system will help lessen the drain on the 12V.
Old Jun 24, 2021 | 12:53 PM
2008 Prius's Avatar
Thanks for the fast reply.
Can you walk me through disabling the Smartkey system?
Old Jun 24, 2021 | 01:31 PM
There is a "KEY" button below the steering column. In is disabled, out is enabled.
Old Jun 24, 2021 | 01:43 PM
2008 Prius's Avatar
Got it thanks.
One more question...
In general, does disabling this make a real difference, or just negligible?
Thanks.
Old Jun 24, 2021 | 04:07 PM
It is most meaningful when driven once a week or less frequently.
Old Jun 25, 2021 | 06:14 AM
2008 Prius's Avatar
Thank you very much. You have been very helpful!
accent2010
Feb 22, 2021 03:15 PM
Curated Content Editor
Oct 10, 2014 09:50 AM
runchadrun
Jun 6, 2007 07:46 AM
tonto
Nov 4, 2005 02:40 AM
JOE540CI
Toyota Highlander Hybrid
Oct 24, 2005 06:30 AM
