08 FEH, high revs when hill climing
Old Aug 4, 2023 | 05:19 AM
ugmw177's Avatar
Default 08 FEH, high revs when hill climing
Son called me from across the country and said it seems that when he is driving up hill, car revs really high like up to 5500 rpms to climb the hill. Not exactly sure about the condiditons as i have not driven car in nearly 2 years. Just curious if others have experienced this and what caused it. Thinking maybe the ICE is working harder to accelerate now if battery pack is getting weaker and electric motor is adding less boost?
Old Aug 4, 2023 | 06:36 PM
Default Re: 08 FEH, high revs when hill climing
This, and it depends on the hill. A steep incline over a long distance will tap out any battery. Recommend he get Forscan and check the BCM data.
Old Aug 6, 2023 | 02:02 PM
ugmw177's Avatar
Thanks, not sure he has the understanding to do the Forscan stuff. I assume BCM is battery control module data?
THanks
Old Aug 6, 2023 | 02:04 PM
THanks
http://www.forscan.org - it's a very inexpensive purpose-built tool that yields near professional level diagnostics.
Yes. BCM is the computer that monitors the battery and interfaces with the PCM for hybrid system management
Old Sep 25, 2023 | 10:37 PM
It's pretty normal if you are heavy on the pedal on hills coupled with driving at a high rate of speed on hills.
Without being there, the odds are it was normal for what was being asked of it. It's a small, low torque engine.
Zoom On
Dec 28, 2007 06:04 AM
davisdesignsolutions
Oct 23, 2007 09:13 PM
David Price
Oct 31, 2006 02:25 PM
hardifeh
Nov 27, 2005 11:47 PM
jimbarstow
Aug 3, 2005 12:40 AM
