Ford Escape 2011 Hybrid Problem
Old Sep 1, 2021 | 04:22 AM
shotiko13's Avatar
Default Ford Escape 2011 Hybrid Problem
Hello
at first so sorry for my english
my Ford Escape 2011 Hybrid has a problem.
when i turn on AC (conditioner) after that doesnot work on hybrid. every time work on Petrol and light "BRAKE" on monitor write "check brake system"
master when he test on program tell me problem is vacuum pump
i exchenag 3 ways and problem not solved
after that i change part which is on photo
What could be another reason?
Old Sep 1, 2021 | 06:33 AM
ShadyEscape's Avatar
Default Re: Ford Escape 2011 Hybrid Problem
Check power to vacuum pump. Does it run?
Old Sep 1, 2021 | 07:18 AM
shotiko13's Avatar
yes, i check and working
Old Sep 2, 2021 | 04:57 AM
Get the code from the brake system. My code was air in the brakes, uneven pressure. Diagnosing by changing parts is a bad way to fix it.
Old Dec 1, 2021 | 10:38 AM
sepmaret11's Avatar
Not too familiar on the Escape in other areas, but the Engine/Hybrid was designed by Toyota, it is very reliable. Used in the Fusion hybrids as well. As long as it seem
Old Dec 1, 2021 | 11:03 AM
Originally Posted by sepmaret11
Not too familiar on the Escape in other areas, but the Engine/Hybrid was designed by Toyota, it is very reliable. Used in the Fusion hybrids as well. As long as it seems well Kodi nox maintained it should be a great car.
Not entirely correct. They licensed Toyota patented technology to design their own. Toyota engineers had no hand in the design of the Ford system.
https://www.wardsauto.com/news-analy...-hybrid-escape
Old Jun 15, 2022 | 12:54 AM
shotiko13's Avatar
my problem is actual
can not fix
has anyone idea where is problem ?
Old Jun 15, 2022 | 07:36 AM
If the A/C doesn't work and it is hot it will always run on petrol because it can't cool the battery. Pull the list of codes from the car and post it.
Old Jun 15, 2022 | 08:34 PM
FEH 2005-2009 had a separate A/C evaporator assembly to cool the battery. 2010-2012 do not. If your cabin AC is not functioning (you should see vent temperatures in the mid-40s F at least) the cabin AC cannot cool down the battery and the computer will not allow it to work when the battery is over temp. 100 degrees F or more and you're basically screwed.
This happened partially as a result of the 2008 financial crisis in the United States. Ford deleted the most important component in the battery cooling system to save some manufacturing money. They also wanted to kill the platform off because they were planning the beautiful new 2013-2000 Escapes, which are gigantic pieces of horse excrement from a Eurodesign engineering and maintenance point of view.
Your battery may "bounce back" but the A/C has to work 100% and the battery cooling system has to work 100% or you are pounding salt.
Old Jun 15, 2022 | 08:38 PM
It's an Aisin transaxle. Ford may have licensed it but it's an Aisin. Ford doesn't rhyme with Aisin so they never stuck a badge on it.
nmorriss
10
Nov 2, 2021 10:56 PM
adent42
Jul 13, 2021 05:26 PM
Eric Ditwiler
Ford Motor Company
Feb 23, 2020 12:27 PM
xraymarc
Jul 31, 2018 08:00 PM
coolrizTCH11
Jan 1, 2014 08:58 AM
