- Ima
- Alternator?
- CVT Failure
- Cooling HCH 1 battery pack while discharging?
- HCH1 NiMH conversion to LiBCM with 40%Hack equivalent
- Free hch1 items
- What's making this noise?
- Need wiring & pinout diagrams for HCH1 Manual trans
- Alternative to discharge/charge cycle with driving?
- P1637 MCM internal circuit failure
- Need help understanding battery cooling fan circuit and Maxxvolts fan control
- CVT push belts
- Replacing Engine Mounts on HCH I
- Best way to get a couple hundred more miles out of a bad start clutch?
- Pack Charging setup
- If hybrid pack tests ok, what else could it be? Opinions needed.
- Removing IMA Battery and Bridging Generator 144v to dc - dc 12v converter
- Code P1569
- EGR Ports and Valve questions
- Maxx Volts Grid Charger instructions?
- 2003 hch ima issues
- Shields on underbody of HCH I
- grid charging advice
- 2005 Honda Civic Hy code 1575
- Best place to buy replacement battery cell packs
- Free hch 03 stuff - Portland OR
- Tires for 2004 Civic Hybrid
- MPG display HCH 1
- '05 HCH headlight moisture
- 2003 HCH - IMA issues
- Steering wanders on 03 civic
- 2005 HCH IMA parts descriptions needed
- Is it time to replace the hybrid battery pack?
- Should these 3 steering switches have lightbulbs?
- 3 time charge discharge, a month of no IMA lights
- Need help with Prolong Battery Discharger
- Worth Replacing Battery Cells with 106K
- how to test that IPU fan blows?
- Little help diagnosing a discharge debacle.
- IF disable Hybrid battery with Breaker, will it still throw CEL for bad battery?
- Building a discharger: 1 bulb vs. 2 bulbs?
- Possible to read individual stick voltages with battery installed?
- Purchasing 05 hybrid manual w bad ima
- 2003 honda civic hybrid, serpentine belt broke
- BCM versions
- parking pawl doesn't seem to work
- One broken bolt on trans case
- Voltage / current ranges during normal operation?
- 2003 HCH transponder key question.
- battery troubleshooting
- Started trans teardown and forgot to partake one photo
- questions about Freshening 2005 HCH CVT trans
- For 05 honda civc hybrid modifications
- 2003 HCH knock retard question.
- Swap packs on 2004 HCH I
- 2004 hybrid rough acceleration and p0420
- Torque specs on a 2004 civic hybrid manual trans flywheel??
- MAP Sensor location 2005 Civic Hybrid
- Voltswagon retires
- P1555 and P1600 Check Engine / IMA light after reconditioning battery
- 2004 Civic- Won't charge 12v (or IMA)
- Where is the oil leaking from??!
- Installing Maxx Volt Charger
- Rattling plastic trim
- 2005 HCH flash codes
- 2,400 mile road trip with p1449?
- Having trouble replacing seals on my 04 hybrid
- 2005 HCH Issue
- Questions about replacing my ignition switch.
- HCH1 IMA Battery individual cell testing
- Can I cut out my catalytics if they're damaged?
- IMA not charging or assisting
- 2005 HCH1 battery fixing
- Temp gauge fluctuating and coolant reservoir overflowing
- What happened? New battery, and I'm idling in a parking lot with the ac running...
- 2003 honda civic hybrid manual transmission swap plus alternator
- 2005 HCH1 code 1440 - IMA motor burnt up three windings
- 2005 Civic A/C Weirdness
- Can you diy refurbish a bad hybrid battery??
- Secondary battery? Huh?
- no crank, no start
- Engine light after hybrid battery replacement
- 2003 hch: I need an emissions label
- IMA Light and P1637
- engine codes 1590,1585,1600,1440
- How much can I get for a used hybrid battery?
- Replacing NI-MH batteries to Li-ion?
- Location of pcv valve?
- New battery pack replacement, 12v light and shutoff still happening
- No pack power after discharge attempt
- 2004 civic hybrid... engine is missing bad on hill climbs
- TCM transmission control module 05 HCH
- 2004 civic hybrid 12v battery light
- IACV removal
- SAFETY warning for pack rebuild
- Changing serpentine belt to bypass a/c
- Breaker in Off position, Red Battery light on regardless of RPM
- Auto Lock/Unlock Feature
- idle unstable 2005
- Which charger is best to weed out bad sticks?
- I've just about had it with this dang thing...
- No cruise control
- AC Clutch Pulley Wobble WITH new bearing
- P1679 Error Code
- Replacement battery failure inquiry
- Dead 12V DC DC converter
- 12v plug/dash lights flicker sporatically
- Reverse lights not working
- New battery, no charge bars
- 12 volt replacement
- Serpentine belt replacement
- Radiator overfill
- Grid charge after voltage stable?
- IMA light on, what to do (help)
- P1600, P1593 and replacement Hybrid battery is not charging.
- Floor jack use for tire rotation?
- Crank no start Honda Civic hybrid 03
- Just bought a 2003 Civic and a spare battery
- P1600, P1433 and main battery is not charging
- Repairs (shock absorber)
- P1445 & P1600 w/IMA, Check engline and red battery lights
- Even with breaker off you're not 100% safe
- P1564 and p1571
- Starting problem
- 2004 HCH buy or pass?
- Transmission position switch?
- 03 HCH good candidate for grid charging?
- Just purchased 2005 HCH red 12v battery and IMA light are on
- 2005 Civic interior light not working right
- 2005 Civic: is the window main switch button lit?
- 05 Honda Civic Hybrid -- IMA failure -- What should I do?
- 2005 Civic: all backlight buttons dead
- Change CVT fluid, in driveway, clearance?
- CVT Torque problem
- Resurrecting a 15 year old, 4 month out of service battery pack!
- Well this is concerning...
- What to avoid when buying a pack for parts?
- hch 1 ima acting crazy.
- Can I get an integrated key/remote for 1st generation Honda Civic Hybrid?
- Very early HCH
- Won't start, need a jump every time plus lots more
- temperature sensors
- So I got an OBD2 scanner....
- with IMA light 12V battery will not charge below 1500 RPM
- Random drag then let go at highway speed
- auto stop stalled, then ran like i was dragging a deal elephant
- P1600 code, no IMA light CEL is on
- Manual transmission removal HCH1
- HCH1 DIY IMA Reconditioning
- "Building" a discharger
- Odd mpg increase with P1600 / P1433 codes
- HCH-I IMA and charging issues
- Anyone know what a P1670 fault code is?
- first gen IMA software update?
- IMA Fan Runs Constantly after Grid Charger Install
- Discharge and Charge VIA IMA in car possible?
- What to inspect during Test Drive
- Going price for salvage HCH1 battery
- Clunk when accelerating from 20-35 MPH
- 12V, IMA, CEL On with new IMA Battery
- Motor Mounts
- Bought a 03 civic hybrid. Issue with transmission fluid
- Please Help me find an O2 sensor
- Ima & cel hch 2003 - smog check issue
- Battery draining losing all power!
- Amsoil Synthetic CVT fluid
- CVT fluid color vs. time?
- ASC hybrid
- Water in headlight
- A/C clutch problem
- Future 04 HCH-I Owner Q's
- things needed to reconditioned 03-05 civic hybrid battery cells
- A/C oomph?
- Battery (12v) goes dead overnight (sometimes)
- 03 Civic Hybrid MT P1570 & P1600
- Bought used 03 HCH at 80k miles. Should I get transmission fluid replaced?
- HCH I Audio Upgrade
- CVT Survey
- DC-DC Converter Pinout
- IMA Voltage Issues
- 2004 HCH1 Heavy Steering
- Honda Civic Hybrid code issues...
- Grinding noise from CVT
- Types of HCH1 IMA batteries?
- HCH-1 Rear defrost "auto on"?
- Check Engine Light on: P0497 EVAP System Low Purge Flow
- Bridgestone B381 tire replacement
- SZCA Civic CVT Trans-Need Overhaul Manual
- New IMA battery; 12v, check engine, and IMA lights are on. Not charging.
- IMA diagnostics
- Idle Air Control And Crank Sensor Clean/Replace
- Where is the fuel filter?
- Replacement clips for 2004 HCH underbody panel
- Maintenance tips: 68k 2004 HCH I w/new 12v and battery pack
- Is it safe to remove the belt from an old IMA?
- HCH I (2004) drive cycle steps?
- 2004 Manual with codes P1435 and P1570 - dealer wants $6000 to repair
- New HCH owner...learning on the curve
- New on HCV
- 05 HCH IMA Light Preventing Emissions Pass
- IMA Battery replaced, IMA light still on
- IMA battery not starting car
- Poor Acceleration/Higher RPM/More Assist
- Plate Bracket Options
- P1570, P1600 after accident
- Honda Civic Hybrid MPG drop
- 2005 HCH Start Clutch
- Rear seatback fitment
- Stick refurb via cycling - why it's a waste of time
- 2003 ignition coils front and rear???
- Battery not charging? Easy way to reset IMA control modules
- Strut replacment suggestions paried with OEM Springs?
- 2004 HCH with P1433 & P0171 Codes - What is my next step?
- HCH1 New IMA Battery, Stubborn Engine Codes
- should i buy a high milesage 04/05 HCH
- 05 Civic: Is my tranny about to fail?
- help, trunk latch stuck shut, no access through battery compartment
- Buying the best grid charger
- 04 Civic IMA Charging Problems
- HCH1 IMA battery voltage reading & reconditioning
- Keep it or Dump it
- Side Airbag Warning Light on when wet outside.
- Obituary for my 2005 Honda Civic Hybrid
- 05 IMA problem
- HCH 1 - P1433 and P0420
- ASC IMA Battery
- Tire Time - All Suggestions out there are OLDDDD!
- PCV valve location
- Anyone used a Hybrid Automotive grid charger?
- weird multiple problems all of a sudden
- IMA Charging....
- Repair Question....
- 12 Volt Battery Question....
- HCH and gen1 insights cells
- Hybridautomotive Grid Chargers
- New To Me '05 Civic Hybrid - Got a List of Questions :)
- 03 HCH wiring diagrams
- P1639 Code in 2003 HCH?
- Think she is totaled?
- Auto Stop not working after clutch replacement
- Any Advice on Getting Replacement Battery Pack to work?
- Possible to intentionally prevent battery from charging?
- 2005 Honda Civic with a dead Battery Pack
- Iron Levels in Transmission Fluid, Oil Analysis
- Someone explain this car's o2 sensors to me (p0420)
- Imax B6 Charging Help
- MPG question
- 2004 Civic IMA MCM question
- 2004 HCH - Bumblee battery, now MPG is plummeting
