Need help with Prolong Battery Discharger
Old Mar 16, 2021 | 09:12 AM
MCoday's Avatar
Default Need help with Prolong Battery Discharger
I bought a Prolong Battery Discharger on ebay and I have tried to use several times, but it does not seem to work. I opened up the case to see if it had an internal fuse that might be blown. I did not find an internal fuse and I did not spot any obvious problem that suggested anything has burned out, but the unit does have a loose wire. I have attached pictures. Does anyone know where this wire is supposed to connect? I can't believe that this wire with a loop style connector is supposed to just be loose within the case.
Is anyone familiar with this unit? Or have one and want to take a couple minutes to open the lid and see where should be connected.
I think maybe it is supposed to just be connected to one of the mounts to the pcb on the lower surface of unit.
I have sent photos to the Hybrid Automotive folks but they were only interested in having me ship the unit to them for possible repair, they did not seem interested in just telling me where that wire should be connected.
Mike
Old Mar 16, 2021 | 09:40 AM
Default Re: Need help with Prolong Battery Discharger
Mike
You don't see a fuse?
With a PCB label like "TH1", and it's position, I suspect that's an internal temperature sensor.
Old Mar 16, 2021 | 11:34 AM
MCoday's Avatar
Not my best moment. Thanks for the help. I was expecting to find an inline fuse like the one that Prolong uses inside their charger. I checked this fuse, guess what? It's blown. Ok, going to try a new fuse and leaving that wire loose and see what happens.
Thank you, Steve
Old Mar 16, 2021 | 12:16 PM
We all have days like that. Hopefully that does it.
dirt657
Toyota Motor Corporation
Mar 22, 2022 02:26 PM
btarb24
May 3, 2019 04:12 PM
FEH_FEH
Dec 17, 2018 07:44 PM
CamTaco
Jun 27, 2016 01:58 PM
wix256
Jan 6, 2014 07:02 PM
