View Full Version : Honda Civic Hybrid
Pages :
1]
- What’s the Average Cost for Auto Glass Replacement?
- Choosing the Right Window Tint: What Should I Know Before Tinting My Car Windows?
- 2008 Civic hybrid 12v not charging P0A94
- Buy or steer clear (2012 Honda Civic Hybrid
- Hybrid civic 2007 huge vibration accelerating from a stop
- 2007 Honda civic hybrid battery replacement after dying after jump starts
- Thud noise when first start car or while sitting parked with car running for a bit
- 2007 Honda Civic Hybrid making a strange Vibrating noise
- 2012 Civic P0A27 IMA failures
- OBD2 Scanner not working
- Interchangeable Modules
- 2015 AC blowing warm air
- continuous clicking from behind rear seat, no start
- Help please hybrid battery (A/C)
- 2003 HCH with suspected knock
- Honda civic hybrid help
- Battery level fluctuates - Civic 07
- civic 2008 charging issue help
- Grid charger for 2004 civic Hybrid
- p1446 issue, I have changed every thing.. need help
- 2004 civic hybrid IMA code 73-1
- 06 civic hybrid
- Engine Swap
- IMA+ Battery + Check Engine light on. SOS
- Recharging AC on 2010 Honda Civic Hybrid
- Codes after Hellish repair (including new P0A7F)
- Installing used AC compressor. Oil?
- 2008 civic hybrid oil pan removal
- windshield fluid reservoir - 2013 Civic Hybrid
- 2008 Honda Civic Hybrid A/C Warm
- 2006 Civic Grid charger
- When to replace the HYBRID battery?
- Honda Civic Hybrid Code
- IMA light
- 2004 civic hybrid IMA light, check engine light and additional symptoms occurring
- 2003 civic. Hybird
- Starter Clutch
- 2003 civic hybrid stereo wiring
- 2008 Honda Civic AC Belt Bypass
- Bad Mileage on Honda Civic Hybrid FD3
- Help! HCH issues with 12v charging and potentially something else.
- 2012 Civic IMA Problem
- 2012 Civic Hybrid problem. Please, help!
- 2005 hch code p0521
- 2008 Civic Hybrid Gas Tank Repair?
- 2006 Honda Civic hybrid problem
- 2004 Civic Hybrid CVT transmission, swap or rebuild?
- Honda Civic Hybrid 2004 won't move in any gear.
- 2009 Honda Civic Hybrid
- Compression test 06 civic hybrid
- Driving with IMA battery out of the car
- Crank but no start
- IMA batteries questions
- 2009 Hybrid Battery Issues
- Do not buy from Maxx-Volts
- 2003 Honda Civic Hybrid IMA light is on
- For 05 honda civc hybrid modifications
- 2008 honda civic 1.3 hybrid ima charging but 12volt isnt
- Fresh air green light always illuminated
- HONDA Civic 2007 IMA
- 2008 Honda Civic Hybrid Gas Mileage Issue
- value of 03 Hybrid for parts?
- HVAC control panel differences
- Miplaced IMA battery sticks.
- Looking for bad inverter for parts
- How to reset 69-4 Honda Civic Permanent code
- IMA issue
- 2012 Honda Civic Hybrid IMA issue
- 8th Gen (HYBRID) P0A7f appears after Engine replacement
- I'd like to replace my a/c compressor with and alternator
- Can i tranny swapp my 04 civic hybrid ato to a 5 speed
- 2004 Honda Civic hybrid
- Civic Hybrid IMA failure - Bad Power Inverter
- Strange battery in my 2007 Civic...
- Question
- Help
- 2003 atf fill
- Check Engine Light/Thermostat Code despite entire system being serviced
- Transmission fluid level check
- 05 Honda Civic 5 speed hybrid Lost acceleration
- Electrophoresis Box for Grid Charging - 2005 Civic Hybrid
- Help with my hybrid! (03 civic)
- Swapped Batteries - Grid Charged - now IMA, battery, & CEL on, also won’t charge/assi
- Brakes
- 2007 Honda Civic IMA. Help IMA light but system working
- 2004 honda civic hybrid
- 2008 Civic Hybrid where is the flasher relay located
- big hills in a 04 civic hybrid?
- HCH 2008 won’t start - jumping starts it momentarily but then dies right away
- Grid charger Parts
- just bought 2004 civic hybrid
- 2003 Honda Civic Hybrid code P1420
- Drive indicator light flashing
- New (to me) 2005 Honda civic hybrid
- swamping 06 civic battery sticks with a 2012?
- Battery is dead??
- Advice for a HCH?
- Help! 2005 Honda Civic Hybrid won't start!
- Unsteady idle / pulsing acceleration - Clean Idle Air Control Valve?
- 2005 Honda Civic Hybrid - Possible AC Compressor bearing issue?
- Honda Civic IMA 2004 Battery / Voltage Questions Please help
- 2005 Civic Hybrid in 'great condition' can't keep 12V charged.
- Honda fit hybrid gp1 issues
- 04 Civic hybrid,reverse but drive doesn't work
- Can a lemon get new life?
- Help
- Car stops working then works again 1-2 hours later
- Buying a IMA battery
- New Battery, Recurring Issues. Help!
- Civic 2014 IMA Battery vs HCH2 2007
- 335K in my 2003 HCH and still going....
- Should I recharge the AC myself?
- inside weatherstrip and trunk lid light
- Can I fix the weatherstrip?
- Looking for a glove recommendation
- Considering purchasing 05 Civic Hybrid
- 1st Gen Honda Civic Transmission Mount repair
- Civic 08 Hybrid replacement IMA
- Honda civic Hybrid 2006 Engine number location
- Regenerative Braking - Not Working?
- Mixing CVT fluids
- Low humming coming from battery, now accessory battery light on
- 12V battery change reset?
- Replacing Honda Civic battery pack with ford fusion pack
- New windshield car going south
- 2007 hch random misfire on all cylinders.
- '10 Honda Civic Hybrid
- charging?
- Will there be another Civic Hybrid in the future?
- Difference between hybrid battery cells
- Sometimes 12v charge light
- Sold it - Have spare parts For Sale
- 2004 HCH needs catalytic converter - ideas?
- 2005 Civic Hybrid Sat for Four Years
- ima battery on / off switch
- 2012 need new ac compressor already?
- Vibrating, Grinding Feeling from 0-10 mph
- Unable to loosen IMA battery grounding bolt
- Civic 2014 touch panel wants code after charging 12 volt battery
- 2005 Civic Hybrid Radiator Bleeding/Burping - Cabin Heat Issue
- 2005 Civic Hybrid CVT Transmission
- 2012 Civic jump start issue
- New to forum - have '03 HCH stick with IMA problem
- Vehicle Battery Prices Plummet
- Im getting around 40mpg highway, but only 14mpg city
- Battery assit behavior vs Gen 1 insight
- Help finding module
- Cvt or ATF fluid
- Preferred 0w-20 motor oil?
- Knocking (detonation), HCH II, 2009
- 07 HCH II, Transmission Failure at 90K, which one to get?
- 05 Civic Hybrid Rear Speakers Replace
- 05 HCH battery: replace/recondition? Low usage affecting battery life?
- My 2012 Honda Civic Hybrid wiring problem
- Replacing the IMA sticks that have sensor wires
- 2004 Civic Hybrid: worth it to fix and sell, or should I just sell?
- Any experience with Hybrid Revolt?
- 2012 Civic Hybrid sitting idle for months
- I totaled my hybrid, pulled battery - how to I test for damage?
- Thinking of buying a 05 civic hybrid, thoughts?
- Best way to sell a car with questionable battery?
- Honda civic hybrid 2003 manual transmission
- Need help 07 Ima and battery light
- (2008 Civic Hybrid) Just Got the Dreaded P0A7F Code - Am I Covered?
- Not Great MPG-What am I Doing Wrong?
- Front Oxygen sensor or Honda Civic 2005 hybrid (cheap)
- Battery reconditioning voltage measurement
- For sale: 4 Blizzak tires / 4 wheels
- 2008 HCH MPG problems?
- CAN A 2005, 2006 Battery be converted
- 2009 Honda Civic Hybrid new tire
- Can't find Low Rolling Resistance-14 inch
- 2008 HCH IMA Battery Replacement - Help Me Deal With the Dealer!
- 2003 Civic Hybrid - Only 18-22 MPG??
- 69-04 - OBD2 code meaning
- Best MPH for MPG's on highway?
- Air Conditioning really affect MPG?
- CVT Transmission Grinding, Video inside
- I need help getting better MPGs.
- Getting Honda to warranty battery before 150k?
- Ac compressor grinding
- Grinding noise
- AC Clutch not engaging
- How does the elec flywheel get power if spinning?
- 2007 Civic Hybrid IMA issues
- Honda civic hybrid 2007 showing all check lights
- 2007 HCH IMA light/check engine
- Need new hybrid batteries for 2006 civic
- No more Honda hybrids!!!
- NBW WORLD RECORD - 120 mile per gallon in a 2003 Civic hybrid!!!!
- 2006 Civic Hybrid has shifter locking
- 2005 civic CVT problem
- Just got a 2007 HCH - How should I maintain it?
- Civic Hybrid IMA problems after fuel screw up
- Wanted: Tow bar bracket
- Engine rotation
- 2004 Civic Hybrid Controller ?
- 2003 Civic IMA questions
- 06 honda hybrid
- 2005 Civic Hybrid won't crank after radio install
- Maintenance Minder Issues
- 2009 Civic Hybrid for my daughter, Problems during googling
- WANTED - Blue Ox tow bar bracket
- Please recommend all-season tires
- Reset computer using thread off Toyota post
- Wierd problem with auto shut off............
- Replace Head Gasket
- What MPG are you guys getting on your HCH II?
- Help me!!! My hybrid sucks :(
- 2003 Honda civic hybrid part out lot of parts
- Jerky Electric Motor Engagement
- ODB-II ScanTool alternative
- battery current sensor for 2008 honda civic hybrid
- Auto stop
- Braking causes regen gauge to max out green bars?
- IMA problems
- Honda Warranty War
- Replaced IMA Battery and car still won't hold a charge
- Weak battery when start-dies
- I just lost 5mpg going to a 5 pound lighter volk wheels how is this possible
- Please see this video and help me
- New Hybrid with bad IMA battery?
- Honda Hybrid : 2004 - IMA Battery is going to Die
- HCH2 Adjusting idle speed
- Idle/Stalling Issue. Please HELP!
- HCH2 warranty IMA Battery replacement
- Rat are vacuum hose
- Amp and sub in HCHII
- Support bar on converter
- Hch 06 in extreme cold problem
- Sound system upgrade, advice?
- IMA Battery Replacement Options?
- Question about fuel cleaner additives
- IMA fails in extreme cold?
- 12v and IMA die every few hours?
- Check engine light on 2006HCH
- Low mileage & Factory warranty on 2008 Civic Hybrid
- Will this be a solution to my IMA battery failure?
- Check Engine / IMA Light On!
- spark knock
- Need HcH-savvy shop near Round Rock/Austin TX
- CEL Due to Deteriorating Hybrid Battery & Emissions Inspection
- Want new wheels
- Is it safe to use 20w oil on a HCH II?
- HCH II to HCH I CVT Swap
- Tire Question
- 2006 Civic Hybrid MPG
