2008 honda civic 1.3 hybrid ima charging but 12volt isnt
Old Jul 25, 2020 | 10:04 AM
Billyhavoc's Avatar
Default 2008 honda civic 1.3 hybrid ima charging but 12volt isnt
I have a 2008 honda civic hybrid ima battery seems to be charging but the 12volt battery isnt. No check engine codes only thing showing up is the battery light. I turn over the ignition and i hear a clicking noise coming from the back. I already got the seats taken out of car to try and diagnose. Could this be a fuse problem or something else? The car has 136000 miles on it.
Old Jul 27, 2020 | 12:45 AM
Default Re: 2008 honda civic 1.3 hybrid ima charging but 12volt isnt
Never a bad idea to check fuses.
Assuming IMA battery is good.
Bad 12V
Bad DC-Dc converter
Old Jul 27, 2020 | 09:07 AM
Billyhavoc's Avatar
The code for dc to dc converter is showing up. It says dc to dc malfunction. Is there a fuse for the dc converter?
Old Jul 27, 2020 | 09:20 AM
The diagnostic code for P0A94 does not reference a fuse.
Diagnostic steps until resolved:
Terminal lug in under-hood fuse box, tighten 7.2 ft-lb or repair if damaged.
Terminal lug in IPU compartment (under red plastic cover), tighten, 7.2 ft-lb or repair if damaged.
Replace DC-DC converter.
Also, while in the IPU, good idea to remove and reinstall all accessible connectors to insure good connection.
snoc20
Jul 13, 2020 01:05 AM
Bin
Apr 22, 2020 01:58 PM
ameme
Jan 5, 2014 06:21 PM
nday
May 5, 2013 07:33 PM
