2008 civic hybrid oil pan removal
Old Jul 22, 2022 | 11:15 PM
John 1982's Avatar
Default 2008 civic hybrid oil pan removal
This is my first post and I seriously hope someone can give me some insight, I was rotating tires and the car shifted, the front jack came off the subframe and punctured the oil pan, I found some replacement pans and took down the engine, I removed all 10 bolts but the pan won't separate, I've tried wedging scredrivers ana hammering but only gaps on 1 side, I don't know if I have to remove the electric stator bolted on the side, I have a replacement engine without the electric motor attached and there's no bolt holes with the stator removed so I don't think something is holding it from within the ima housing, I want to remove the broken oil pan and put a new one cause I don't need to replace the entire engine, any advice is greatly appreciated
Old Jan 18, 2023 | 10:20 PM
Alisad's Avatar
Default Re: 2008 civic hybrid oil pan removal
You have to remove the down pipe, remove the ac compressor and bracket behind it, then lower thr cross member (x6 "17mm" head bolts).
192.168.100.1 192.168.1.1
Felix J Hawkswell
May 28, 2019 03:18 PM
gistecknician
Jul 17, 2012 02:09 PM
evois
Jun 27, 2012 08:22 PM
gistecknician
Jun 26, 2012 02:40 PM
UWAdventurer
Mar 20, 2008 03:02 PM
