69-04 - OBD2 code meaning
Old Sep 10, 2015 | 11:17 AM
Club3kgt's Avatar
Thumbs up 69-04 - OBD2 code meaning
Hi guys I am getting a couple obd2 codes showing up most having to do with the IMA battery but I have searched online and have found nothing on this code.
69-04 - IMA system malfunction 2, Line pressure solenoid valve A stuck ON.
Thank you,
Frank
Old Sep 10, 2015 | 12:14 PM
Default Re: 69-04 - OBD2 code meaning
If you're using a cheap OBD reader, they can give goofy results. With Torque Lite and an ELM327 bluetooth adapter, I got a couple fake codes. It hasn't happened with Torque Pro.
I would address the other codes first, reset and see if it returns.
What are the other codes?
Old Sep 10, 2015 | 01:50 PM
Valalvax's Avatar
Torque Lite also transposed several codes on me, P0300, P0301, P0303, and P0304 became P0300, P0103, P0303, and P0403
Old Sep 10, 2015 | 05:26 PM
Club3kgt's Avatar
Hey there, well my car is getting around 18-22 mpg on the cluster gauge . Heres the rest of the codes.
P1600 - IMA system malfunction
P0420 - catalyst system efficiency below threshold (bank 1)
P1449- ??
67-01 - catalyst B2 deterioration 2 below threshold 3 and 4 and B1, 5 and B2 ; deterioration 6 threshold 7 below threshold B2
69-04 - IMA system malfunction 2, line pressure solenoid valve A stuck ON
Thanks guys!
Old Sep 10, 2015 | 05:30 PM
Club3kgt's Avatar
The obd2 scanner tool is the: INNOVA 3110 which is pretty good quality.
Old Sep 10, 2015 | 09:15 PM
Oh. now I see I'm replying to you in multiple threads on the same posts. Thanks.
Pick a thread, and we can continue. I still maintain the 67 and 69 codes are false codes related to the cat and batt codes.
P1449 means your pack is in a bad state.
Steve
dabs
Oct 11, 2012 08:29 AM
oldag98
Aug 2, 2012 06:11 PM
haroldo
Feb 16, 2009 01:12 PM
cohybrid
Sep 19, 2006 08:41 PM
JackC
Off Topic
Feb 19, 2004 11:43 AM
