69-04 - OBD2 code meaning
Hi guys I am getting a couple obd2 codes showing up most having to do with the IMA battery but I have searched online and have found nothing on this code.
69-04 - IMA system malfunction 2, Line pressure solenoid valve A stuck ON. Thank you, Frank |
Re: 69-04 - OBD2 code meaning
If you're using a cheap OBD reader, they can give goofy results. With Torque Lite and an ELM327 bluetooth adapter, I got a couple fake codes. It hasn't happened with Torque Pro.
I would address the other codes first, reset and see if it returns. What are the other codes? |
Torque Lite also transposed several codes on me, P0300, P0301, P0303, and P0304 became P0300, P0103, P0303, and P0403
(Post 257731)
I would address the other codes first, reset and see if it returns. What are the other codes? P1600 - IMA system malfunction P0420 - catalyst system efficiency below threshold (bank 1) P1449- ?? 67-01 - catalyst B2 deterioration 2 below threshold 3 and 4 and B1, 5 and B2 ; deterioration 6 threshold 7 below threshold B2 69-04 - IMA system malfunction 2, line pressure solenoid valve A stuck ON Thanks guys! |
The obd2 scanner tool is the: INNOVA 3110 which is pretty good quality.
Thanks |
Oh. now I see I'm replying to you in multiple threads on the same posts. Thanks.
Pick a thread, and we can continue. I still maintain the 67 and 69 codes are false codes related to the cat and batt codes. P1449 means your pack is in a bad state. Steve |
