View Full Version : Honda Civic Hybrid
Pages :
2]
- need help with getting password for radio
- 2005 hch p2000 & p1600
- Poor mileage after starting battery disconnected
- Civic 2004 battery replacement. Used one ?
- Can't pass emission inspection due to P1600 and P1449 codes
- 2004 Honda Civic Hybrid Tranmission issue or Flywheel?
- New owner - 2003 Honda Civic Hybrid
- 2004 Civic Hybrid, Cylinder Leak- Blown Head Gasket?
- Checking the trasmission fluid in a '03 Honda Civic Hybrid...
- 2003 Honda civic hybrid
- hch as a backup electric generator
- Tires Or Alignment Causing Swerving On Grooved Pavement?
- Battery question
- Best O2 SENSOR
- 2003 HCH A/C system repair/ electrical questions
- Changing rims.
- Honda Civic jerking
- Michelin Defender vs. Nokian eNTYRE
- Civic Hybrid 09 concerns
- Fs 02-03 civic hybrid fogs
- Battery success story!
- Time for a new Car - Dashboard looks like a Christmas tree!
- IMA, Check Engine light on, operates nomally
- 2003-2008 Civic IMA Warranty Extension
- Replace battery, but no charge
- Is this the regular or IMA battery?
- What Determines Level of System Charge?
- 2008 Honda Civic Hybrid
- 2003 HCH Hybrid Battery Rebuild
- -5F + Check engine light + IMA warning light on
- 2003 HCH went in okay, came out dead.
- Check Engine Light
- alarm system help!
- Please help!
- HELP! Both batteries dead 2006 HCH and just bought used 6 months ago!
- 2003 Honda Civic Amp and Sub
- considering buying a 2004 honda civic hybrid need guidance
- IMA Battery
- Oops... meant to edit
- Honda civic hybrid 07 shaking issue
- LCD Language is in Japanese
- Brake Pads for 2007 HCH
- Selling my 07 HCH II
- IMA in New York
- Manual IMA for HCH1 now availible.
- Has anyone here replaced an IMA battery?
- HCH Settlement Proceeding
- WTB: Rear Hybrid Badge
- IMA and Check Enging Light on at only 29,000 miles!!
- SZCA 2005 Civic Hybrid Transmission Parts
- Battery(?) Problem
- replacing a dead civic 2006 hybrid battery with a modified accord hybrid battery
- Fuel Recovery Cannister? Valve? Hose? $1400?
- Honda Hybrid over 260,000
- Should the 2009/10 HCH hwy fuel economy be comparable to 05/06/07 models?
- What do HCH repairs cost?
- Audio Upgrade for '07 HCH
- Quick advice needed on 2003 Civic Hybrid with 89k miles for $8,900
- toggle switch under dash?
- Just bought a used Honda civic 2006. Need help.
- VW Diesel convert
- Out with the HCH, in with the CRUZE
- OBD2 scan and computer safe mode
- 2004 civic engine noise in drive
- Should I Buy This 2003 Civic Hybrid?
- Leaking Oil pan, Need Help
- 2004 HCH sputter when turning over engine?
- Underneath/Side panel material... bumpy?
- Battery charge/discharge indicator not showing
- HOV Exemption in NOVA extended indefinitely!
- Questions before buying a 2005 Honda Civic Hybrid
- hch 2007
- Honda warranty extension for secondary/third O2
- 12v battery change
- IMA Light P1600 code
- DMV forces mandatory emission recall to renew car registration for Honda Civic Hybrid
- How to change my transmission fluid/filter
- Water in battery vent
- EliteHybidCars
- Auto-stop lights
- 2009 HCH Question
- Rear Main Seal
- hybrid-battery.com -- Is this a scam?
- IMA Warranty Question Texas > California
- Hello and a question
- Changing brake pads on '07 HCH
- what is it like to drive the HCH without the IMA? part 4. Good news/bad news
- 2005 Honda Civic Hybrid 12 Volt Issues
- what is it like to drive the HCH without the IMA? Part 3 Better news
- what is it like to drive the HCH without the IMA? Part 2
- How to Damage IMA
- Car WIll not START. After Valve adjustment
- 2007 civic hybrid IMA battery issue
- Hybrid V Norma Cars MPG
- Honda Civic Hybrid 2007 AUX input
- Hybrid small claims lawsuit..
- Lousy mileage but good performance
- In need of some good advice
- Results on the junkyard battery
- Engine error codes
- Crankshaft Pulley bolt
- 06 Civic Hybrid - catalytic converter
- P1420 - O2 Sensor Question
- 2006 HCH - IMA going- CODE P0A7F- options ?
- 2003 Honda Civic Hybrid - stalls after cleaning EGR
- 2009 Civic Hybrid Tires/Mileage - Help!
- PERFECT 15inch combo
- 2003 HCH, Sluggish acceleration, new battery helps?
- Honda Civic Hybrid 2005 for Sale CA
- 12V not charging after replacing it!!!
- Low Rolling Resistance Tires
- Need Advice: Trade In or Sell 2007 HCH - no nav in DFW
- start clutch in 2003 honda civic hybrid
- HCH Settlement - new update!
- 2003 Honda Civic Hybrid Audio HELP!
- What is the best way to remove the Yellow HOV sticker
- IMA Warranty Transferable to new owner?
- 2006 Civic Colors
- Tire Pressure:losing 6 psi per week
- 2005 hch
- 2005 hch cvt
- 2004 Honda Civic Hybrid Oxygen Sensor Recall?
- fault code p1356?
- New transmission for a 2005 HCH. What?!?!
- 2004 hch won't start after few mins of stopping
- Honda Civic 2006 - battery jump starts, but engine immediately dies
- 2003 civic steering wheel cover?
- 2003 honda hybrid: IMA battery, catalytic converter
- 2005 Honda Civic Won't Start
- Fixing Broken Gas Gauge?
- Honda Civic 2003 IMA 1.3
- IMA Battery, how to check?
- Just bought civic IMA 2004 having problems
- 2005 Civic Hybrid AC removal?
- bad manual transmission bearings
- HELP!! No dash lights horn and windows dont work and wont START :( 07 civic
- Dead Civic
- CVT Fluid
- Recommend IMA mechanic near Los Angeles?
- Getting our First Hybrid
- IMA battery problem?
- Rumbling noise when assisting while starting
- Help HCH problems
- Very Strange Sound From CVT
- Buying a 2004 Honda Civic Hybrid ...what to consider
- Thinking of jumping ship
- I'm hearing the starter 2006 HCH
- Reprogramming Hybrid Computer
- CA HOV Stickers
- 2012 Civic
- Defroster button - take a look and see what you think
- I would not buy a HYBRID if I could do it again
- Check this Spark Plug. is this GOOD?
- 2007 Civic Hybrid Head 240 PSI Engine Compression? What the HELL. is this normal?
- Listen to my Head Valve Clicking. What do you think?
- Tires and Transmission Fluid after 24,000? Seriously?
- 2007 Civic Hybrid Head JOB, Burn Exhaust Valve
- Aftermarket rims for 2006 Honda Hybrid
- Things I should know now that I own a Honda Hybrid
- HCH II Mods
- Couple of Problems..03 HCH
- AUX Plug and MPG on a Hybrid Civic
- Mobil 1 Bargain Price
- I (apparently) suck at hybrid driving.
- 2012 Honda Civic launches with new HF model; hybrid goes lithium
- Poor mileage ~ 2006 honda civic hybrid
- Tips to prolong your HCH I or II battery pack (ver 1.0)
- P1420 on Civic Hybrid
- Checking Transmission fluid interval
- HondaCare...only available at time of purchase?
- IMA Light but no code???
- 06 HCH keyless entry not working
- Civic Overheating
- Replace IMA Battery yourself?
- 06 HCH no start
- Win a Sony Playstation 3 (PS3) or Gran Turismo 5
- Upper Control Arms In Australia
- Insight II Auto Stop - From Manual
- Idle Hunting
- P0420 - Check Engine Light - 07 HCHII
- Nitto Tire on Facebook, LIKE to win tires
- looking at a $3900 03 civic hybrid with 131K
- Opted for Honda Fit
- exhaust heat power recovery
- IMPORTANT INFO! Honda IMA Warranty
- DIY 70k Service on HCH 2
- Does Honda Cover the Service Bulliten 08-001(Uneven Rapid Tire Wear)?
- Honda civic 2004 Beeping noise constantly
- 2003 Honda Civic Hybrid overheating. Cannot find reason.
- Miles until empty
- Fuel Mileage Gauge
- 2006 HCH - lost power steering- briefly
- slightly undersized firestone affinity tires
- Battery problem
- 06 HCH, 75K miles- no maint/ service
- Class Action Law Suit
- Civic Hybrid 2006 starting/ignition problems, battery related?
- check engine light and ima is on
- Broken Radio antenna
- Tape Deck Or CD Player?
- Honda Civic Hybrid Intake or K&N Filter
- plz help me
- Anyone enhance the factory stereo?
- 2006 HCH Brake Pads -
- New Used Hybrid Owner Concerns
- Air conditioning kills IMA Battery - 2006 HCH
- '05 heat WAY TOO HOT
- Ca hov sticker extension - to july 2011!!!!
- Retraction Of Previous Post
- tips and mods to make your honda civic hybrid run as should be
- Not Very Happy With Civic Hybrid
- Honda Civic IMA & Check Engine Light
- 2009 Hybrid Software Update
- 2007 HCH, had updates done. :)
- battery fumes coming into car
- Augmenting the internal combustion side
- Anyone have any tech info on Recal?
- Auto Idle Stop Fix-Strange Computer Reset?
- Clutch Replacement Done In A Repair Shop But Not Satisfied
- Civic Hybrid Doesn't Require Special Kind of Fuel
- New HCH owner here, What to expect ?
- 2008 civic hybrid sudden acceleration
- IMA Discharging issues-Help
- Please Help with Ima and battery lights
- Civic Hybrid Interior and Exterior
- Hybrid Cars Consume Less Fuel
- Idle problem with 2006 civic hybrid
- Engine Prob after picking up car from Auto Body Shop
- A/C Problem - How to turn it off?
- surging when climbing hill
- Taking off issues with transmission?
- HCH 2003 Code P1420 ???
- Aux Jack gives mono sound?
- Installing rear seatcovers problem
- Upgrading 2009 HCH Audio System?
- "Catching" when accelerating. Safe?
- Changing it up
- Supercharging a Civic Hyrid??
- Way to manually charge the IMA battery?
- IMA System Indicator & Malfunction Indicator Lamps came on at the same time.
- Do Extended warranties cover Battery Pack? (05 Civic Hybrid 98K)
- 2007 HCH Leak
- Should I buy a 2005 HCH
- What to do?
- USB Drive Issue
- 2009 Civic Hybrid - IMA Light Comes On
- Is there a problem?
