Please Help with Ima and battery lights
Old May 20, 2010 | 10:48 AM
Mauricio187's Avatar
Default Please Help with Ima and battery lights
I made the huge mistake of leaving a the dome light on in my 2006 civic hybrid. It drained the battery so I had to jumpstart it. I know a lot of things can go wrong with the car if you jumpstart it. I called Honda and they said everything would be fine. I jumpstarted it and at first it wouldn't start. Second try it started on the gas engine. The Ima and battery lights are now on and the battery is not being charged. I can't move it because when I put it in drive it feels like it's going to die. And the drive light on the dash is blinking. What's wrong. This car is so delicate. It's kinda annoying. I've had it for a week.
Old May 20, 2010 | 12:39 PM
kristian's Avatar
Default Re: Please Help with Ima and battery lights
The drive light blinking usually indicates a transmission problem (I've seen that twice on my car--which is currently in the shop getting a new tranny put in). The first time it was just because a rotational sensor was out of whack and it was fine after the dealer reset something. I think you should bring it to a dealership and have them check things out.
Old May 20, 2010 | 07:47 PM
Mendel Leisk's Avatar
The 12 volt battery is pretty small, and easily depleted by a light left on. You may be able to restore it with a charger, or the dealership might. Either way, something has to be done: a near-death 12 volt battery will need attention. It ticks me off: it is very easy to leave a light or two on and kill the 12 volt. There are no built-in safeguards.
I keep one CTEK 3300 charger in the trunk now:
http://www.ctek.com/EN-US/Buy-US-Charger.aspx
It's good for maintenance re-charging, and could save your bacon on vacation somewhere. It claims to be an "intelligent" charger, fwiw. It's a fairly light amperage though. In my experience with near-dead battery, it took 2~3 overnight sessions to fully recharge with a 6 amp auto charger.
For higher capacity, you might consider a traditional metal box 6 amp charger. Get one that automatically reduces the charge as it nears recharged state.
Also FWIW, I did a pre-emptive replacement of our 12 volt battery, about 6 months back. It had been through 2 or 3 close calls, and I just figured it best to replace it. IMO it's best to look on the 12 volt as a consumable: if it's done you 4~5 years, count your blessings and replace it.
Old May 30, 2010 | 02:54 AM
GreenBoy's Avatar
I think it is advisable if you just go to Honda for that matter. I'm pretty sure they can do something about that problem. Maybe you let them handle that to avoid another conflict.
cody07hch
Aug 18, 2019 09:11 PM
tiggerx1
17
Oct 24, 2010 10:50 AM
bbmotor
Jul 28, 2010 11:34 AM
jamriman
Oct 30, 2008 07:19 AM
Sorsha
Oct 29, 2008 12:36 PM
