2012 Civic IMA Problem
Old May 31, 2021 | 02:02 PM
ItsAWonderfulDay22's Avatar
Default 2012 Civic IMA Problem
While coming to a stop, the car jerked and 4 lights came on. The check engine light, IMA light, brake system light, and charging system light (red battery) all came on.
The OBD 2 scanner revealed 5 codes:
P0A27 - Battery power off circuit
P1440 - IMA system problem
P15A5 - Motor current sensor circuit malfunction
P1437 - Motor power inverter (MPI) module short circuit
P0AE1 - Hybrid battery precharge contractor circuit
The car drives pretty ok in the city with only a small power loss. However, when accelerating to get on the highway, the car kicked once, like a rough shift in an automatic. Then it wouldn't hold speed no matter how hard I pressed the gas. The engine didn't rev high. I let my foot off of the gas and pushed down again, and suddenly the gas pedal worked like normal again.
All the dealership service centers are closed so I haven't gotten a second opinion from them yet. I can only go off of the codes and symptoms until tomorrow. IMA fuses are not blown.
Any idea what might be broken?
Old Jun 7, 2022 | 12:44 PM
agoke's Avatar
Default Re: 2012 Civic IMA Problem
__________________________________________________ ___________i had the same scenario mentioned in the 1st sentence only I only threw code p1437. Ever find out what happened?
Old Jun 7, 2022 | 12:45 PM
agoke's Avatar
apgary
Jan 12, 2025 06:56 AM
EastR84
Dec 9, 2024 09:10 AM
vugar_1973
Apr 28, 2021 10:16 PM
Honda hybrid guy
Mar 24, 2016 03:09 PM
Guygo159
Oct 12, 2012 09:31 AM
