Problem Starting 2012 TCH with "Ready" Light
Old Jan 15, 2018 | 01:06 PM
EastR84's Avatar
Default Problem Starting 2012 TCH with "Ready" Light
In the last few weeks, my 2012 LE TCH will not start. All the dashboard lights illuminate (and stay on -- see picture) except for the green "READY" light. I will cycle through the power on/off with my foot on the brake to re-try and turn off the A/C, radio and headlights, but I get stuck in the same cycle of the car not powering up. The only way I have found to fix this is leave the car, wait a minute or so, then get back in and the car powers up fine with the ready light. I have just over 86k and the issue only comes up once every 20-30 times I try to start the car. I did a trickle charge to the 12V battery (an Optima Yellow Top D35) but it is only 1 1/2 years old so it shouldn't be dead yet. Any ideas? Thanks in advance.
Old Jan 15, 2018 | 05:25 PM
Default Re: Problem Starting 2012 TCH with "Ready" Light
I've seen Optimas be DOA, and I've seen them crap the bed in less than a year.
Load test the 12V.
Key fob battery putting out weak signal? Replace key fob battery?
Old Jan 15, 2018 | 06:09 PM
EastR84's Avatar
How to load test the 12V? I have a voltimeter.
I've seen Optimas
Load test the 12V.
Old Jan 15, 2018 | 07:44 PM
Amazon Amazon
or pull the battery and take it to an auto parts store.
Old Jan 16, 2018 | 04:43 AM
EastR84's Avatar
https://www.amazon.com/Schumacher-BT...eywords=bt-100
Thanks! Does it matter that it is an AGM battery? Optima makes a big deal out of this.
Old Jan 16, 2018 | 05:37 AM
No. AGM have different charge requirements (lower current and usually a lower peak voltage). They should handle 10 seconds of 100A load with no issue.
Old Jan 16, 2018 | 06:53 PM
EastR84's Avatar
Thanks so much for the help. Went with an OEM Panasonic AGM battery today from the dealer. They took off 10% so it was $250 which came out less than the current rate on the Optima D35 at $280 on Amazon, so I'm hoping this is the solution.
Old Jan 16, 2018 | 07:02 PM
Did you have it tested before replacing it? Good choice, BTW. The OEM batteries are good.
Old Dec 9, 2024 | 09:10 AM
Smash's Avatar
Hi
Did you solve the problem with the new battery?
Winchester_Fire
Aug 21, 2016 07:40 AM
robmck
50
Dec 27, 2009 05:10 AM
k0712s
Nov 7, 2009 05:52 AM
cooperk851
Aug 14, 2009 04:04 AM
hybie1
Aug 29, 2008 06:55 PM
