Help finding module
Old Jun 11, 2016 | 08:33 AM
GrnrGrl's Avatar
Default Help finding module
My 2003 Honda Civic Hybrid stopped charging last fall. Found a local auto repair shop that has a certified hybrid repair tech. I was in no hurry to get it repaired (having surgeries, not driving much, second car etc) and they were willing to work with me on a delayed time frame. Over the winter they determined the problem was not the hybrid battery but one of the two modules that work like an alternator. I do not have the exact part #, but the shop is having trouble locating it in the secondary market, as they say there are no new ones being made. I trust them, and have heard of hybrid owners having this issue. Not sure who their sources are. Questions: 1) is this a common problem with the older cars? 2) anyone have suggestions for more vendors/sources, 3) if they can't get the part, then what!?! Sell my otherwise good car for parts? I was hoping to use this and the second car to upgrade to one newer vehicle. Don't need two anymore. Help!
Old Jun 14, 2016 | 06:58 AM
Default Re: Help finding module
MCM and BCM failures are FAR LESS COMMON than battery failures. MCM and BCM units are readily available from salvage yards.
It sounds like they may have diagnosed your DC-DC converter as bad. Again... DC-DC converters are FAR LESS COMMON than battery failures; however, they should be readily available from salvage yards.
Old Jun 17, 2016 | 10:37 AM
GrnrGrl's Avatar
Thank you. Will check with the tech to make sure exactly which part it is, and that they are checking salvage yards.
meerkat
Sep 1, 2008 07:21 AM
texaskiwi
Nov 13, 2007 07:05 AM
CA Girl
Off Topic
Sep 6, 2007 05:45 AM
Lilarienne
Nov 6, 2006 11:21 AM
flare
Aug 3, 2004 12:46 PM
