I need help getting better MPGs.
Old Aug 29, 2015 | 12:14 PM
Rjim3195's Avatar
Angry I need help getting better MPGs.
I have a 08 HCH with 145K miles and I'm only getting 20 to 28 MPG's. I have my IMA battery replace from the dealer at 125K miles. I just replaced my spark plugs at130K miles. I have Goodyear fuel max tires with good thread @ 38PSI. I just got my Trans drained and filled as well.The only maintenance I haven't done is adjust my valves. What do you guys recommend I do???
Old Aug 29, 2015 | 06:59 PM
Default Re: I need help getting better MPGs.
Is this a new development? What mileage did you get right after the battery was replaced?
Is your battery recalibrating? Shows 6-8 bars, then rapidly drops to 2 bars at about 1 bar/second, then force charges with no assist? After that it may either start to behave normally once it hits 3 bars OR, it will stay near 3 bars and then go to full at 1 bar per second.
What are your driving conditions? speed, terrain, traffic, etc.?
A/C use?
Old Aug 30, 2015 | 02:05 PM
hunter44102's Avatar
You can almost rule the battery out with that low of mileage. Even with no battery at all, you should get 40MPG highway and about 30 City.
Check your tire pressure. Should be at least 38PSI per tire.
clean throttle body and make sure air filter is good.
remove all extra weight/items from trunk and back/front seats
make sure wheels spin freely (check brakes)
Davis_Walker
Oct 7, 2014 04:48 PM
bruno
Jul 22, 2013 10:14 AM
odp101
Jul 31, 2011 05:51 AM
Jason
Jun 5, 2005 09:21 AM
tmrpro
May 22, 2004 01:57 PM
