PDA
View Full Version : HCH I-Specific Discussions
Pages : 1 2 [3]
  1. Check Engine + IMA light...then IMA goes off?
  2. 2004 IMA; Offset steering
  3. Error codes???
  4. HCH Battery Problem
  5. Tires slip when accelerating (regularly) in rain
  6. Hybrid battery clunking and creaking
  7. ScanGaugeII use.
  8. Uninvited guests?
  9. Why not a trunk tray?
  10. 2003 AC Compressor
  11. A/C Problem
  12. Tire advice needed
  13. Battery Charge Level Indicator
  14. anyone tried hybrid-battery-repair.com?
  15. K&N Air Filter and Better FE
  16. Questions on used 2004 HCH
  17. 200,000 miles? No troubles!
  18. Atkinson engine cycle?
  19. NGK Iridion or Denso Platinum?
  20. 2003 Honda Civic Hybrid question
  21. Hybrid Battery Replacement Instructions
  22. Navi/BT/XM Install
  23. Automotive error code reader?
  24. catalytic converter class action lawsuit
  25. 2003 Honda Civic Hybrid
  26. After-market catalytic converter?
  27. 2009 New Owner
  28. Fuel Economy Took a Dive. :(
  29. Buying a 2003 HCH (need help quick!)
  30. IMA battery charge level = 0 after diconnecting battery?
  31. Check engine light came on today
  32. Stock CD player line-in?
  33. IMA Light Dash Picture, Please Explain
  34. Thrown rod on a HCH? Honda was no help.
  35. Warranty extension to 157,000 miles?
  36. Acceleration and brake noise- just bought a used HCH
  37. failed IMA
  38. Savings on service with hybrids
  39. HCH I Lowbeam headlamps
  40. 2003 auto stop question
  41. Newbie - MPG advice needed
  42. Oxygen sensor questions 2005 HCH
  43. Newbie - New Battery too
  44. bubbling sounds
  45. Squeaking/creaking sound on cold days
  46. 03 Hybrid Center Antenna
  47. 2003 Foglight installation - Help
  48. Start clutch gone out
  49. Winter Tires
  50. IMA and check engine lights on
  51. HCH I with Thule T2 1.25 hitch
  52. Ignorance is expensive
  53. New IMA batteries better than old?
  54. wow, just paid 16 bucks a spark plug @ honda!
  55. HCH I customs
  56. Starting Problem
  57. Brake bleeding procedure?
  58. 2009 Hch
  59. Manual transmission problem, whining
  60. Forced Auto-Stop??
  61. What's Better? Take off hard or easy?
  62. hybrid integration
  63. Braking makes funny noise
  64. HCH 1 on Michelin X Radials
  65. HELP! Won't start
  66. Question about HEAD & DIM light
  67. Just when will battery die
  68. HCH1 suspension
  69. Alway remember ......least we forget
  70. Ugly Noise from A/C
  71. Tires
  72. 12-volt Battery - Any relationship w/ Hybrid Battery?
  73. Noise (Fan?) after Turning Car Off - 2003 HCH
  74. Altering Computer?
  75. HCH Flood Damage (Salvage)
  76. Picking up an 03 HCH CVT tomorrow!
  77. Any recent IMA/Battery Replacements?
  78. What brand is the spare
  79. '03 Civic with 140K miles - a good buy?
  80. Getting disappointing mileage...
  81. New (used) 2004 HCHI MT Questions
  82. Oxygen sensor failure, 33k miles
  83. Cruise control on a 2005 IMA MT
  84. Charging on level ground?
  85. Changed Gas Type
  86. different size tires
  87. 2 probs; CVT and Clicking
  88. High RPM Problem
  89. battery fan
  90. my HCH
  91. My HCH experience with 5W20 instead of 0W20
  92. New Owner - 2005 HCH 5 speed
  93. Need Help Please Read!!!!!!!
  94. Failed IMA Battery Owners!
  95. Fs: 2005 Hch
  96. Buying an 03 HCH w/CVT - what do I need to ask?
  97. What is this thing??
  98. New Problem with 2003 HCH
  99. Battery life
  100. Camshaft
  101. Workshop manual
  102. Broken Fuel Gauge
  103. Check engine light on, and weird IMA issues
  104. Battery Problems
  105. Running day light on american mondel
  106. software update for MT also?
  107. alternator (12V) symptoms, lifespan
  108. Heater control module replaced
  109. Owner's manual
  110. Third Catalytic Converter Blown!
  111. Oil Changes
  112. Orange IMA warning light turned on.. HELP!
  113. considering 2005 HCH purchase - wind question
  114. considering 2005 HCH purchase - wind question
  115. Transmission Slips going Down hill??
  116. Rear wheel fender skirts
  117. looking at buying used '03 hch with 112k miles and trouble codes
  118. New Tires
  119. Electric Shock when leaving
  120. Pre-purchase advice on 2003 HCH?
  121. HCH 1 Repair Manual
  122. Is there a extended warranty for 2003 HCH battery?
  123. 05 HCH-1 starts,revs,dies
  124. DC/DC Converter, IMA Control Unit, ABS Control Unit
  125. New Civics with Leather Seats
  126. New wheels
  127. re-registrating hch 1 in tx.
  128. bottom line Who has talked to hybrid mechanic
  129. New Honda Extended Transmission Warranty
  130. Instantaneous MPG gone
  131. competition clutch: mileage advantages?
  132. adjustable camber arms for the rear
  133. Re: List of FAQ & DIY Links for 01-05 Civic
  134. 5-speed 2003 HCH bucking at low throttle
  135. Wheel offset for 05 HCH
  136. Anyone use a obdii reader on HCH-I?
  137. Anyone else at 120,000 miles?
  138. 04 HCH CVT Steering problem- 21k miles
  139. Replacing Starter in 03 HCH
  140. maint req'd blinking HCH 04 CVT 75 k miles
  141. A little thing that I really like about my 5 speed HCH
  142. Different wheels?
  143. HCH I a ULEV or SULEV, what's the diff?
  144. Thinking about buying 03 HCH CVT
  145. Which FSM?
  146. Thought i might get you opinions on this, clunking noise from the front suspension?
  147. New Recall 03-05 HCH July 2007
  148. Timing Belt - Civic Hybrid
  149. 04 Hybrid Problem, Drivability issues with my 7gen hybrid
  150. How long can you drive w/o IMA/Battery?
  151. Honda Transmission Oil
  152. 5 speed auto stop
  153. 04 mt battery behavior
  154. Battery Charging
  155. Loose Shift Knob, '04 HCH
  156. Red battery light flashes
  157. Red battery light flashes
  158. Sunroof anyone?
  159. Fuel Filters (again)
  160. What's FAS?
  161. Auto Stop\Starter Wear?
  162. 2005 HCH - only getting 36mpg
  163. Anyone self-install their EGR valve?
  164. Need help with spark plug change!
  165. Valve Adjustment/Timing Belt?
  166. CVT Question
  167. Has anyone replaced the antenna ?
  168. Under carriage cowling
  169. Stupid Question...PRNDSL
  170. Civic Hybrid Manual Transmission
  171. Bad surging/lunging at slow speeds.
  172. Maint Req'd light
  173. Anybody remove interior door trim?
  174. Tire Recommendation for HCH1?
  175. Anyone have their engine not start after auto-stop?
  176. IMA Battery Needs Replaced
  177. Honda Owner Link
  178. Doing an Oil Change
  179. transmission safety concerns addressed
  180. CIVIC IMA 2004 CVT good buy??
  181. HCH 2004 Original Stereo
  182. PCV Valve Replacement
  183. Wiper blade sizes
  184. Power Steering
  185. 2004 HCH IMA Problem?
  186. Can't keep alignment
  187. Sloshing sound behind the dash?
  188. Would I be considered crazy for....
  189. 03 hch auto hiccups and lurches??
  190. 2003 HCH CVT Transmission failed 93,000 miles
  191. 6 CD In Dash
  192. Dealer Says Not to Use Synthetic
  193. Side airbags vs. curtain airbags???
  194. Trunk Access
  195. Lower Engine Cover Part Number?
  196. Key with remote on key?
  197. Inverter Question
  198. Audio upgrade and amp in HCH
  199. Does anyone have the schedule?
  200. Running with no fuel
  201. Broken Tail Light
  202. Trade-In Value of HCH 05
  203. HCH-I Clutch Replacement
  204. Dash Removal for New Stereo
  205. HCH-I (5 spd Manual) Shift Indicator Lights???
  206. Transmission/12v battery problem
  207. Thinking about buying a used civic hybrid
  208. Recall: Software update
  209. EGR valve recall???
  210. Replacement Keys - Why so expensive
  211. HCH CVT: Auto-Stop in Neutral?
  212. Bizzare re-cal?
  213. Any HCH I with rear cup holder ?
  214. Cheapest Honda Care Warranty, please help...
  215. Nationwide parts shortage?
  216. FYI - mpg with car top load
  217. Oil Filter
  218. FAS Questions on 04 HCH with CVT
  219. Special Tires?
  220. FCD recalibration/recall?
  221. Stuck fuel door
  222. transmission check up
  223. Question: Anyone Else Experience This?
  224. Catalytic Converter
  225. Can the CD player be upgraded?
  226. POS Honda (Don't try to take dash apart unless you want to buy a new one)!
  227. 2005 HCH Newbie
  228. For all you HCH I drivers with 50+ MPG...
  229. OK, this is real, my car isn't turning over, display is not there either
  230. Dim display in 03 HCH
  231. Engine cut-out when shifting gears
  232. Summer gas mileage
  233. Donut
  234. fog light compatability question
  235. Who sells a good extended warranty?
  236. Failed IMA
  237. GreenHybrid bumper sticker spotting (Wellington, FL)
  238. Stereo access instructions for opening dash
  239. Newbie 03 MT HCH I Check engine light on
  240. Your stop and go traffic strategies?
  241. Anyone else at 100k?
  242. Just installed K&N flat on my 1st gen HCH
  243. Spark Plugs?
  244. Gen 1 Rulz!!
  245. I knew it was coming..
  246. Just Purchased 2003 HCH 5-speed Manual
