- Kayak, carrying one....
- Diagnosing AC problem
- oil change..
- Brake Locking Up
- Dome Light Wire Location
- LRR Tire Choices or Change Wheels for Better Options?
- Transmisson issues...
- Hybrid battery fan question?
- 2nd 2003 HCH battery FAIL <2 years
- P0443 Evap. Code and mystery plug after engine replacement.
- 2004 Civic Hybrid Battery finally bad, safe to operate?
- Greentec versus Bumblebee IMA Battery
- ScanGauge XGuage specialty guages for first gen Civic Hybrids
- Problems after installing new Head Unit
- IMA battery dead—opt for Bumblebee replacement?
- HCH LRR Tires or Wheel Swap Needed Now
- Help. Both my 12volt and the IMA battery drain over night. 2003 Civic
- IMA System Suddenly Stops
- How to see the min/max on the coolant overflow tank?
- Startup issues
- Battery Trouble.. have salvage battery but no way to tell if good
- Converting car from CVT to Manual Transmission
- Weird Battery charge problem
- 2004 HCH steering feeling heavy
- won't engage reverse gear sometimes
- Differences between CVT Fluid
- Shift Release Button locked
- IMA battery dying in 5-speed HCH1
- Scan Tool
- How to flush coolant out of the CVT
- Orange plug
- Issue with Brake locking up
- How long does the car drive with a bad IMA battery-And overall 260K mile review
- 2003 HCH M/T totalled in RI- part swap?
- Mildly cool air from AC
- Considering used 2005 Civic Hybrid ULEV w. Manual T
- No tach, no power steering, 12V light, ABS light - 2003 HCH
- 2004 Civic Hybrid just stopped working (the Hybrid part)
- New owner 2005 hch cvt
- A/C problem with Hybrid
- how to change transmission cable
- 2005 dead need advise
- Check Engine light, Battery light, IMA light come one
- Roof Rack
- Roof Rack
- P1600/IMA/Check Engine Light
- Help with P1600 and P1433
- Whats Different about Hybrid Floor Mats?
- CVT/ DIFF fluid
- Just Fixed IMA...Check Engine Light Still On
- IMA Battery Questions
- OMG - Just talked to the dealer -
- SRS Light - Easy Fix after diagnosis - DTC Codes
- 2005 Alignment rear camber specs?
- 2003 HCH O2 Sensors--which Denso sensors to buy?
- IMA Problems on my Civic!
- Airbag deployment
- Check Engine Light: P0138HO2S-12 (Bank 1 Sensor 2) Circuit High Input
- 03 civic hybrid 5spd 135k
- TPMS- do I have it? 2004 HCH
- CEL and IMA on and red light for 12v battery comes on at idle
- Headlight bulb replacement- 2004 HCH 1
- questions about buying my first HCH I
- About the AC clutch bearing, and why you should keep a short drive belt in the trunk.
- NOOOO! IMA light came on.
- HCH CVT to 6 speed swap?
- Selling 3 year old IMA battery in S. California
- IMA battery performance
- HCH IMA battery failure preventing inspection
- dead car
- HCH 1 05 convert to MT?
- New owner of an '04 HCH 1 5-speed
- 2003 Honda A/C Replace
- Getting codes P1130 & P2000
- Decreased MPG??
- What is the specification for 12 volt battery
- 2003 HCH, need A/C bypass ASAP!
- Front compliance bushing (aka lower control arm bushing)
- a/c heater blower circuit
- Know a good SoCal dealership for warranty work?
- After market cd player will not turn on
- can not find tranny fill plug? please help
- Rear Seat Bench Removal
- Gas Guage Problem
- Burning Oil?
- Full tank problem? Any ideas?
- HCH 2003 with 180K miles Engine Hesitates...Check Enginer light and IMA light on
- engine skid plate hch 1
- Options for 2003 Honda Civic Hybrid IMA battery replacement
- Shudder from stop
- Manual IMA Control HCH1 IMAC&C
- Jerky transmission
- To buy or not to buy an '04 HCH with 116,000
- Battery not charging with cruise control on?
- 2003 O2 Sensors
- Aftermarket Source for Interior Parts
- Leaking Oil pan, Need Help
- Bought a 2003 Civic Hybrid - problems right away what can I do?
- rear shock strut parts
- Hyundai Sonata Hybrid - Lifetime battery Warrantee
- Does recharging of 12 volt battery recharge hybrid battery?
- Check engine and IMA light problem.
- Electrical power distribution problem... maybe?
- Sold my 2005 HCH-I yesterday - post-mortem analysis
- The dreaded P1449 IMA code
- P1600 and P1570 IMA Codes Showing, now what?
- Interesting Gov't Data
- Shop Manual
- CVT Code p1886 - Car Dead
- Oil Change
- DIY Maintenance
- error codes p1435 and p1449
- 2003 HCH - IMA / Charge Issue - P1600, P1575, P1570
- My transmission woes updates
- Thinking of buying a USED 2005 HCH I "Does it still have warranty?"
- cheaper NEO-WEDGE light bulbs?
- Radio removal to install PIE HON98-AUX
- Those those with transmission problems
- Tires for 2003 HCH
- CVT 'BANGS' in/out of gear
- Battery shows 0 charge @ start-up
- '05 HCH CVT rumbles on acceleration
- Strange acceleration dip from stop
- Any fluids I need to keep up on?
- IMA battery Failing on my 06 HCH
- 04 HCH CVT oil leak?
- Just did 130K maintenance, am I missing anything?
- Valve adjustment Go No-Go method?
- Tire pressure
- 2003 HCH-I A/C problems
- Big Thank You. New Owner 2004 HCH
- 2003 HCH-1 front brake rotor and pad replacement
- Serpentine Belt Replacement Instructions
- Airbag light
- Roof Rack Question
- HCH 1 wheel weight?
- Does anyone here knows where it is located the PCV Valve on a HCH 1?
- May buy an HCH, important questions for you guys!
- dealer option 7 spoke wheel
- Not driving HCH
- Fuel gauge problems
- need FCC ID for 2003 HCH-I keyfob
- hello everyone new to site and hybrids
- Thoughts on buying an 03 HCH
- Fuel Filter/Injector Cleaning
- Dreaded IMA Light with Malfunction Indicator Lamp
- Where is filler of transmission oil, HCH 2004
- Check Engine Light Poll
- Beware of Hybrid Battery Repair.com
- new to forum have some questions
- 05 HCH Firewall.
- Got an HC1 and a digital camera? I need a pic...
- No key fobs, buy one on ebay program myself? dealer has to do it?
- Honda Civic Hybrid recall / product advisory ~oxygen sensors and catalytic converter
- Good Balanced Battery still getting p1433
- 12v battery replacement?
- PCV valve
- Serp/timing belt
- Check engine, maintenance and IMA lights on
- A/C compressor
- '04 CVT Starter Clutch
- Adding Transmission filter
- IMA light, codes p1600 and p1433 and O2 sensor link?
- Adding water to Yuasa battery
- 03 HCH 1 Record Tank @ 241,000 Miles
- 2003 HCH 1 @ 182,000 miles
- A/C quit blowing
- squealing when slight turn
- Is MPG reflective of A/C usage?
- 2003 HCH Battery Light, IMA Light, and Check Egine Light
- Newbie needs quick help
- 100 amp junction board fuze
- HCHI Forced Recharge
- 2004 HCH IMA Light - very confused - pls respond
- IMA Control Unit Needs Replaced
- 03 Hybrid Battery fan test
- IMA Only Light....any suggestions?
- How difficult to change serpentine belt 2003
- 05 HCH ABS / IMA Lights
- P0134 02 sensor - no activity
- Factory IMA warranty question
- Fuel Gauge Problems?
- Steve-- Your amazingly high MPG
- check engine light came on for two days then went off.
- Thinking about an '03....
- Tachometer and trans issues
- Brakes and IMA
- IMA warrenty email
- 03 IMA battery part No.
- which cat?
- Should I buy a really high miles HCH I?
- Check Engine + IMA Light
- 2003 HCH Finally Let Me Down
- Charging System Problem ?? Whats Wrong?
- start up problem? it started with the 12Volt starter
- Auto-lock doors
- Gap between hood and side panels on '04?
- Does this happen to you?
- New Hybrid owner
- New hybrid owner, need advice on oil etc.
- Cruise control button lights died
- 2005 HCH transmission shudder (surprise!)
- A/C Compressor clutch
- looking at a $3900 03 civic hybrid with 131K
- 2005 HCH IMA and Check Engine Lights on
- Front suspension failure
- HCH died while driving...?
- Single Key Fob replacement
- Anyone replaced an O2 Sensor to correct a P0134 error code?
- IMA System Malfunction Problems
- Lookin at an 05 Ciciv Hybrid....what am I looking for?
- Humming / Buzzing while in Drive, normal?
- '04 Honda Civic Hybrid
- Honda a "Green" car company?
- '03 HCH - AC Dead
- long time charging, quick discharge
- catalizer
- Help! Failed Emission because of code 1449!
- 1st Gen Honda Hybrid (Insight & Civic) Oil Consumption
- Used 2004 HCH I
- 2003 Honda Civic Hybrid CVT 100K Service?
- Cost of repairing HCH Manual Trans Clutch
- P1600 & p1449
- Removing AC compressor from belt?
- IMA light came on
- New oil from HONDA!
- tips and mods to make your honda civic hybrid run as should be
- New 2003 HCH owner... need tires & new stereo
- Will changing 12v battery affect gas mileage?
- '05 MT Owner -- Anyone else doing their own work?
- Honda Civic Hybrid Transmission Died
- Which service manual?
- How many miles will a '05 Civic Hybrid last?
- engine management light
- Anyone need a Service Manual?
- heater problems
- New 05 HCH Owner - Advise plz
- EGR valve
- Poor planing on my part does not constitute an obligation to help on yours...
- New to the community: new HCH at 35,000
- Rear license plate fell off 2003 HCH
- Periodic Electrical System Anomalie
- OBD Codes, Can you help?
- 12v solar battery charger
- whats needed to convert from a Hybrid?
- Youtube video of my car going over 100,000 miles on original battery
- Keep blowing the 7.5 fuse for interior light
- slow charge, quick discharge
- creaking when steering
- 2004 HCH Shaking
