03 civic hybrid 5spd 135k
Old Feb 7, 2013 | 10:48 AM
JSGrind's Avatar
Default 03 civic hybrid 5spd 135k
Hey guys thanks for any insight in advance. My car was just purchased and it is making a puttering noise when it sits idle. When I drive and push the clutch in the noise subsides. As I'm driving in first gear the puttering noise comes again.
Any help thanks.
Old Feb 11, 2013 | 08:30 AM
notec's Avatar
Default Re: 03 civic hybrid 5spd 135k
It's probably the input shaft bearing in the transmission. It'll get louder the more miles you put on the car. I've got the same problem with mine.
Old Feb 11, 2013 | 10:22 AM
JSGrind's Avatar
I'd that the motor in the middle? What kind of cost is it to replace parts/ labor it's that loud noise under the air box too. Thanks
Old Feb 11, 2013 | 01:17 PM
notec's Avatar
No, I said TRANSMISSION. You know, the thing that the shift lever is attached to? Could be anywhere from $1000 to $4000 depending on where you go.
Old Feb 11, 2013 | 11:46 PM
JSGrind's Avatar
Smile Re: 03 civic hybrid 5spd 135k
Wow that is a major repair I'm really surprised that it's got this kind of an issue. Does anyone know if that's something that would be covered under the ten-year 150,000 mile warranty by Honda under California emissions or is that just for the battery pack?
Thank you for all the help I love these forums!!!
Old Feb 12, 2013 | 05:07 AM
notec's Avatar
Most of that cost is labor, unfortunately.
Old Feb 12, 2013 | 06:13 PM
mrkcohen's Avatar
Moderator
I had the same problem and was lucky enough to find a shop in Johnstown, NY that installed a new bearing/seal kit for about $850. The transmission comes out like any other manual Civic.
NOTE: I did NOT replace the clutch at the same time, saving me a grand or so IIRC. The car still has the same clutch 100K later.
mwill07
Jun 24, 2022 07:30 PM
zexel
Jun 15, 2010 07:36 PM
zexel
Sep 1, 2009 06:06 PM
artyin
Apr 30, 2006 07:51 PM
911Driver
Jul 9, 2005 10:20 AM
