Orange plug
Old Aug 7, 2013 | 06:59 PM
Scott Cook's Avatar
Default Orange plug
I am trying to figure out what it is I am looking at....under the hood on the right side (passenger side) is a unit that has brake lines going in and I assume out and there is a plug on it with a orange handle---What is that unit....it may be the root of my problems--I say that because as someone presses the brake peddle I can hear what sounds like air leaking...any suggestion?
Old Aug 7, 2013 | 07:35 PM
Scott Cook's Avatar
Default Re: Orange plug
ok..since people dont have a clue...does anybody know anything here?? Its the ABS pump unit...as for the air?? I have no clue..
Old Aug 8, 2013 | 11:54 AM
poscivic's Avatar
I think the orange handle is your transmission oil dip stick.
Sounds like you might have have air in your brake lines if you are hearing air. Try bleeding your brakes to see if that helps. Are you having problems stopping at all?
Old Aug 8, 2013 | 08:12 PM
Scott Cook's Avatar
ok first off..the transmission oil dip stick...isnt orange its yellow...and its on the left side (drivers side) of engine compartment.....I have bleed the brakes...I get fluid out on the brake in question.....it is only happening on one tire...and yes the car is stopping...the brake is locking up....the plunger in the caliper is out all the way...it will not retract..as it should when you let out on the brake...there is a weird sound like air hissing when I let out on the brake coming from the ABS modual...when I am hearing the noise the engine isnt running I am just pressing the brake....im at a loss
Old Aug 8, 2013 | 08:14 PM
Scott Cook's Avatar
oh just some additional info...the ABS light is not on in fact the only light that is on is the check engine light but that is pointing to O2 sensor being bad
Joe Green
May 9, 2016 01:45 AM
romwarrior88
Jan 13, 2006 05:15 PM
James
Events & Gatherings
May 16, 2004 10:37 AM
James
Events & Gatherings
May 12, 2004 03:33 PM
