A/C clutch problem
Old Aug 4, 2016 | 06:36 PM
aibaxter's Avatar
Default A/C clutch problem
I have a 2003 civic hybrid. I bought a used a/c compressor off of ebay, and it works fine, but the it was staying on all the time (even when i had the hvac totally off)
my solution was to swap out the clutch. it didn't help.
from what i can tell, my problem seems to be with the shims: i can't seem to get the spacing right.
with the shim, the clutch slips and the ac won't come on.
without the shim, the ac won't disengage.
i know i could just buy a new compressor with all of it together and it would work fine, but this compressor works, & i just paid to have the system evacuated and refilled & i don't want to pay $100 to have it done again if i can help it.
ideas? thanks!!!
Old Aug 4, 2016 | 07:48 PM
Default Re: A/C clutch problem
Check your relay.
Old Aug 5, 2016 | 04:26 AM
aibaxter's Avatar
Check your relay.
can you elaborate? thanks
Old Aug 5, 2016 | 08:14 AM
Compressor clutch relay... The switch that engages the compressor clutch.
Old Aug 10, 2016 | 04:23 AM
aibaxter's Avatar
it is not the relay. i swapped it out to no avail.
Old Aug 10, 2016 | 05:55 AM
What's the field coil resistance?
Old Aug 17, 2016 | 07:31 PM
Phototone's Avatar
I wonder, when you removed the shim, or shims, and replaced the clutch did you determine it would spin the compressor without contact with the engine off? Spin by hand? It needs to be free spin, with only the drag from the compressor which won't be much if everything is not on, not pulled up right on the belt pulley. There has to be a miniscule (very tiny) gap there. Honda says .020. You can measure with feeler guage.
Chadillac
Jun 8, 2016 05:31 PM
Hot_Georgia_2004
Mar 12, 2012 09:10 AM
stevejust
Jan 2, 2009 03:22 AM
SoopahMan
Lexus GS 450h
Sep 17, 2006 02:19 AM
tckma
Sep 15, 2006 02:13 PM
