One broken bolt on trans case
Old Sep 16, 2020 | 04:30 PM
alexdhacher's Avatar
Default One broken bolt on trans case
During a rebuild of the trans I broke a bolt. I've tried extraction and ended up drilling into the threads.
It's one bolt near the forward clutch assm.
can I just be a loser and let it be? Add some gasket goop or rtv?
Old Sep 16, 2020 | 05:26 PM
Default Re: One broken bolt on trans case
helicoil?
Old Sep 20, 2020 | 07:43 AM
I drilled it out. Retapped it.
I didnt want to take it all apart again and have to get new gaskets and wait even longer.
Not sure if it would have leaked missing one bolt..
Old Sep 20, 2020 | 08:14 AM
Good to hear it.
Old Oct 4, 2020 | 09:55 AM
No leaks! Car is running. CVT transmissions are seemingly easier to work on than I expected.
And you only need a few special inexpensive tools.
Old Oct 4, 2020 | 06:02 PM
Congrats!!! What do you charge? My '03 has been sitting in the driveway for a few months because either the CVT has grenaded, or the flywheel drive spline is stripped. Haven't bothered to figure out which...
Old Oct 7, 2020 | 03:38 PM
Once I figured out a few things the drop of the trans was the simplest part.
Getting the original 32mm axle nuts off
disconnecting the 17 year old rusted up exhaust.. And figuring out how to install it later
ball joints were both dead. And I had to get the moog problem solvers as they were swapped before me
learned to pb blaster everything
Supporting the engine and trans with home made 4x4 brace chain, boat trailer hoist and threaded eye bolt.
One tie rod end.
6 Quarts of fluid
ATF filter and 3/8 hose.
6 cans of brake cleaner and degreaser.
3 arm puller
Rust converter for the underside.
Serp belt
Two radiator fan motors. ( both dead. Prob contributing to the transmission failure)
Oil
Oil filter
Air filter
Cabin filter
Old Oct 8, 2020 | 08:33 AM
Sounds like quite a journey to resurrect an old beast.
Old May 22, 2021 | 03:40 PM
its May and its still fluid leak free!
IMA got a home made re-gen, and was good for about 3 months, but the CEL came on for P!449 again. i don't care. its still gets high 40s on the highway. After clearing the CEL,i can go about 20 miles of stop and go before it comes back on.
and it means, it'll pass inspection if i arrive with the CEL on , and then reset just before going in.
alexdhacher
Aug 15, 2020 05:50 AM
John Zheng
Dec 15, 2016 04:10 PM
Earthling
Off Topic
45
Nov 6, 2012 01:55 AM
kalamazoo
Jan 22, 2010 03:53 PM
jvmpc
Oct 9, 2008 09:25 AM
