2004 civic hybrid... engine is missing bad on hill climbs
Old Feb 16, 2019 | 07:31 AM
Thesupersoap33's Avatar
Default 2004 civic hybrid... engine is missing bad on hill climbs
The car is a manual trans with 380k. I bought it with 340k and recently replaced the plugs and coils because the car was missing bad on the road. Ran steady after that. Then I got some remanufactured injectors and replaced those and it's been a headache. First, the wrong ones arrived and were missing, then the right ones came in and they're missing now too, or causing a miss whenever I'm accelerating up hills. Otherwise, the car runs stronger and accelerates with power that it wasn't really showing before.
so my thoughts are that maybe I messed up the wiring harness on the coils and injectors when I had to keep changing everything out maybe. The clip plastic was old and a few were snapping off, but the connections were still snug. This or maybe the injectors are putting too much fuel into the cylinder.
the orings weren't leaking any gas. I didn't put the clips back onto the injectors when tightening back down the fuel rail for the third time. There was a major leak with the first batch of incorrect injectors, but that was remedied by better orings and making sure they seated properly when tightening down the rail.
could their be a vacuum leak?
my other observations are that when the car is missing, the fuel economy gauge goes from over forty to just over 20 mpg. Then if I let off the gas and then restomp, it seems to function fine for a second. Nothing else is going on during the misfire as far as the ima is concerned. It's not charging or discharging during the misfire.
the remans came from an eBay seller. Bought them for 90 bucks.
please help. This is beyond frustrating. Thanks.
Old Feb 16, 2019 | 10:53 AM
Default Re: 2004 civic hybrid... engine is missing bad on hill climbs
plugs and coils fix car
remanufactured injectors broke car
Re-install old injectors?
What codes are you getting?
Vacuum leak would likely manifest at idle and cause other problems.
GreenManHighway
Aug 1, 2019 12:40 PM
houseofcharm
Jul 8, 2017 04:39 PM
Neil
Oct 30, 2016 05:01 PM
hossito
Jan 14, 2015 03:34 PM
Turbotim88
Jul 21, 2011 03:33 PM
