MPG question
Old May 29, 2014 | 10:19 AM
richsbca's Avatar
Wink MPG question
Hello everyone! I got a 2004 HCH and am currently getting around 46.5 mpg. I have noted fluctuations in the mileage where it will go to as low as 40.
I know what everyone is going to say next: 'it's the way you are driving' . I can assure everyone my driving is the same.
I first noticed a change from around 47 mpg down to about 40 after adjusting the valves. I did rotate the crank with the engine off to do the adjustment.
The mpg stayed roughly around 43 -44 for a month or so then after a long trip (yes it was freeway) the mpg jumped to around 50 mpg and stayed like this for at least 2 tanks of fuel. On another recent trip I had a load of people and drove a mountainous route. The mpg dropped to its current state through 1 tank of gas.
My question is does the computer learn and try to adjust fuel consumption based on engine/motor load or driving conditions? It seems the my computer may be changing fuel consumption for some reason. I was thinking it needed to relearn the crank position or something like that since the the MPG dropped after valve adjust and crank movement with engine off.
Is there a way to reset the computer?
Thanks for looking!
Old Jun 9, 2014 | 01:42 PM
richsbca's Avatar
Default Re: MPG question
Seems to be a connection that I have uncovered.
FYI
When I use Chevron unleded/super unleded my mileage jumps to around 50/mpg. If I use Arco, Shell, or Valero the mileage drops to 45 or below.
Haven't tested with Mobile yet.
So far my little car seems to really like Chevron for some reason....
jfreeman
Aug 14, 2012 03:07 AM
mijohnst
Aug 20, 2010 06:22 PM
ShellyD
Sep 14, 2006 08:41 PM
kenny
Aug 22, 2005 04:22 AM
BIF
16
May 8, 2004 05:51 PM
