Database Question - Which MPG?
Old May 2, 2004 | 07:53 PM
BIF's Avatar
BIF
Hi, Folks:
This is mostly for Jason, but I'm sure others may have wondered the same thing...
Which MPG figure should I put in the real mileage database....my MFD one, or the one I calculate manually upon each fillup?
Thanks.
Old May 3, 2004 | 09:21 AM
Hot_Georgia_2004's Avatar
I am inputting data at each tank.
Thanks,
Steve
Old May 3, 2004 | 01:42 PM
Jason's Avatar
Site Founder
Steve, MFD = MultiFunction Display. He's asking if he should use manual calculations or trust the car
In reality, the database is not 100% accurate because there are different ways of calculating averages and cars also have different amounts of error. It is by far easier to use the MFD's reading, as I do. However, if you prefer to do it manually, by all means. If this was a pure Prius community, I would suggest either one or the other, but as GreenHybrid wecomes all hybrid owners as well as other interested individuals, there is little hope we can all come to common grounds.
In short, whatever you want. In the long run, it won't make a huge difference anyway.
Old May 3, 2004 | 06:19 PM
xcel's Avatar
Hi Bif:
___I use actual calculated vs. tank over tank display in the Insight. The database doesn’t use enough digits to store the real world mileage correctly unfortunately. As an example, my lmpg displayed in the Insight is 82.7 mpg, my actual calculated lmpg is 82.824. The LMPG in the Real World Mileage Database shows a 84.2 mpg …
___When Jason revamps the mileage database, I hope he will actually allow it to calculate our mileages like we have done it since the beginning of the automobile. Actual distance traveled/Actual gallons purchased. Hopefully he will add at least 3 digits to the right of the decimal point for gallons purchased and one digit to the left of the decimal point for miles traveled. There won’t be the rounding error with too few digits or none beyond the decimal place to skew the data over time as it appears today …
___Good Luck
___Wayne R. Gerdes
___Waynegerdes@earthlink.net
Old May 3, 2004 | 06:35 PM
Jason's Avatar
Site Founder
I don't see any reason why the database would be that far off. It should have less than .1 MPG error. Can you?
Old May 3, 2004 | 06:43 PM
xcel's Avatar
Hi Jason:
___The lmpg calculate in the database is increasing ~ .2 mpg over an above actual per tank in my case? I will look into it a little closer in the morning as I still have all my fuel, distance, tank, and display data in spreadsheets and still have the actual receipts.
___Good Luck
___Wayne R. Gerdes
Old May 3, 2004 | 07:23 PM
jinno's Avatar
Hi all,
I use actual calculated mpg at the pump.
When we input numbers into the database, although mpg can
be entered to the nearest tenth, it appears that the
number of miles in a tank is accurate only to the whole mile.
I record my miles in my notebook to the nearest tenth. So I
round up or down accordingly. Examples: my dash says I
drove 512.3 miles on a tank, so I enter 512 into the database;
my dash says 516.8, so I enter 517 in the database.
Anyway, it appears that this error results in my personal
lmpg in the database higher (by 0.2) than what I calculate
using number of miles to the nearest tenth and number
of mpg to the nearest tenth.
However, as more tanks are added, this error should "average out."
Maybe we can enter the number of miles to the nearest tenth?
jinno
Old May 3, 2004 | 07:33 PM
Jason's Avatar
Site Founder
Jinno,
I can certainly add this ability when I have time, but have found that in most every odometer, miles are measured to the nearest unit. Perhaps this is not the case when people use Trips instead.
Old May 3, 2004 | 07:35 PM
jinno's Avatar
Good point, Jason. I am looking at the miles on
a single trip in my HCH, which shows miles to the
nearest tenth.
No biggie,
jinno
Old May 4, 2004 | 01:46 PM
Jason's Avatar
Site Founder
Jinno,
On a single trip, eh? Not the odometer. That's the trip meter!
