Transmission position switch?
Old Oct 1, 2017 | 05:38 PM
schmidtc89's Avatar
Default Transmission position switch?
Does the 05 HCH use a transmission switch for reverse detection to light up the reversing lights?
In my 05 auto HCH I have to slightly push the gear selector while in reverse in order for the reverse lights to come on. I can hear a relay clicking in the glove box area when it hits just right and the lights come on.
Is this the relay going out or is there a switch/sensor in the transmission?
Old Aug 17, 2018 | 05:01 PM
vk56dehan's Avatar
Default Re: Transmission position switch?
I just posted the same question to an 03 hch named "reverse lights not working". Hopefully one of us get a reply or link.
Old Aug 17, 2018 | 07:13 PM
schmidtc89's Avatar
I tried adjusting the shifter linkage that goes to the transmission but that didn't seem to fix it. I am thinking there is a shift position switch on the transmission somewhere.
Old Jul 22, 2020 | 07:59 AM
firehawk618's Avatar
Old thread but reviving this.
Mine was doing the same thing. When I put it in reverse the indicator on the dash was dark and no reverse lights. If it wiggled the shifter a little I would hear clicking as well as get the indicator on the dash plus reverse lights.
I just pulled the airbox out, the bracket that supports the air box then I was able to remove the gear selector switch on top of the transmission. It's really easy.
After that there's about 6 screws holding it together. Remove them, take it apart, lightly sand the contacts, reassemble.
All works great now.
vk56dehan
Aug 17, 2018 04:57 PM
UWAdventurer
May 16, 2008 07:25 PM
RedLdr1
May 2, 2008 10:10 AM
rjbarlow
13
Aug 14, 2005 07:41 PM
tbaleno
Feb 13, 2005 03:19 PM
