IMA Charging....
Old Nov 23, 2014 | 06:50 AM
philwford's Avatar
Default IMA Charging....
I read about running up RPMS to 3K to charge , but I also read where you should pull #15 fuse under the hood before you do this...is this true and if so what purpose does pulling the fuse serve....many thanks
Old Nov 24, 2014 | 04:49 AM
Default Re: IMA Charging....
It's the same as disconnecting the 12V battery without losing power to the rest of the systems. It forces a recal, and you typically get more charge for the effort.
Even without a 12V disconnect or a fuse pull, you should be able to rev it to 3K and get it to charge to the top.
tylerginevan
Apr 27, 2015 10:38 AM
Hot_Georgia_2004
Jun 1, 2012 10:21 AM
linx3566
Dec 23, 2009 11:24 AM
ryanh
Honda Insight
Dec 9, 2005 04:25 PM
Mitaka
Oct 7, 2005 07:48 AM
