2005 HCH IMA parts descriptions needed
Old Jul 24, 2021 | 06:24 AM
Jecalea's Avatar
Default 2005 HCH IMA parts descriptions needed
I have several issues with my car. I installed a grid charger thinking that the IMA is not charging the 12V, in doing so I discovered that the IMA fan unit is not running. I replaced the IMA fan, but it is still not running which should run with the grid charger attached. (in another thread I found the charging issue may be related to a relay I can replace)
Can anyone give me a description of the units (or detailed picture) in the IMA compartment so I can figure out what controls the fan and what to replace? Years ago I replaced the CPU with a used unit, perhaps that went bad.
I have 260K+ miles on this car and I'm not ready to give it up! If anyone has suggestions for the issue as well, I'd appreciate it. I'm mechanically able but I don't know all the jargon or abbreviations used in some of these threads, like MCM for instance, please spell it out for me.
Old Jul 25, 2021 | 01:31 PM
Default Re: 2005 HCH IMA parts descriptions needed
What grid charger?
Old Jul 25, 2021 | 04:07 PM
Jecalea's Avatar
What grid charger?
Maxx Volts
Old Jul 25, 2021 | 04:52 PM
Did you confirm you properly connected the fan controller?
Old Jul 26, 2021 | 01:32 PM
Jecalea's Avatar
Yes, I did take apart the connectors to verify the wires were pierced by the connectors.
Old Jul 26, 2021 | 06:25 PM
Then you have two bad fans. The MV charger should be powering the fan independent of the car.
thomas1978jc
Dec 4, 2012 10:31 AM
Bweisbuch
Jan 16, 2009 07:34 PM
tya2agt
Jul 15, 2008 12:16 PM
cardio75
May 24, 2006 04:53 AM
