Changing serpentine belt to bypass a/c
Old Jan 7, 2019 | 12:36 PM
hpcbmw's Avatar
Default Changing serpentine belt to bypass a/c
Just got a 2004 Civic hybrid pretty cheap, in part due to air conditioner motor seized up. I'm hoping to replace the serpentine belt with a shorter one and bypass the AC. Will this work? If so, any links to a diy on changing the serp belt?
Thanks!
Old Jan 7, 2019 | 09:06 PM
hpcbmw's Avatar
Default Re: Changing serpentine belt to bypass a/c
After some digging, I found a diagram of the a/c bypass with a size for the correct replacement belt (398k4). The belt routing didn't make sense to me, since the belt doesn't seem to have much contact with the water pump pulley, but obviously this is how people are doing it. Once I figured out the routing, it only took about 20 minutes to actually change the belt. Here's the link and the routing diagram:
http://runnells.name/blog/?p=523
Christopher Covahey
Jun 7, 2018 11:20 AM
Mike Thompson
Toyota Highlander Hybrid
Sep 19, 2017 08:24 PM
grnhybrid
Sep 16, 2011 10:15 AM
houstoib
Aug 31, 2011 12:44 PM
UWAdventurer
Jun 24, 2010 07:48 AM
