PDA
View Full Version : Toyota Highlander Hybrid
Pages : [1] 2
  1. Brake pedal hard 06 highlander hybrid
  2. 4wd versus awd?
  3. Tires for toyota highlander limited hybrid
  4. Need 12V battery recommendation for 2010 Highlander Hybrid Limited
  5. Where to buy modules
  6. Low EV battery
  7. I'm considering a used 1st/2nd Gen Highlander Hybrid w/ 100k+ miles
  8. 23 Highlander Hybrid dead
  9. 07 Highlander Hybrid mAh Blade Capacity
  10. 2006 Highlander Refrigerant
  11. 08 hybrid EV Conversion, Tesla X Killer
  12. Performance upgrades?
  13. Where to purchase HV Battery Pack???
  14. Can you disable the electric drive system?
  15. Hack my traction control
  16. 06 Brake Replacement
  17. 07 brake "clicking" noise while braking
  18. Hybrid repair problems
  19. Adding more battery capacity?
  20. Knocking sound from 06 HiHy transmission?
  21. inverter crapped out at 44k
  22. Keep your car clean!!
  23. DIY battery rehab on 2006 HiHy possible?
  24. Spark plugs change 2012 Highlander Hybrid
  25. How can my 2007 Toyota Highlander Hybrid be running with no belt?
  26. Advice on whether to buy 2013 Highlander Hybrid (39K miles)
  27. 2ng gen highlander hybrid in snow
  28. Highlander Hybrid Grill blocking to increase MPG in cold weather
  29. 06 highlander emergency flashers problems
  30. ABS, VSC and Brake Warning
  31. 2012 HiHY CVT fluid change
  32. Economy driving zone
  33. Timing chain
  34. Special equipment for 2007 HiHy inverter coolant change?
  35. Burning Oil - Normal?
  36. HH 2008 with 215K miles.
  37. Button top left of shift lever area.
  38. Have Loaded '06 HiHy Limited w/120K miles...what is it worth
  39. Knocking type noise when at idle.
  40. Highlander hybrid perforance parts?
  41. Brake mechanism noise (pads? calipers? ABS?)
  42. Glove compartment door
  43. Changing CVT fluid
  44. High Idle in Winter
  45. Brake Caliper sticking
  46. water pump and timing belt
  47. Coastal Tech EV mod on Highlander
  48. 07 HiHY VSC on after brake pad swap
  49. ‘Close Fuel Lid’ Indicator Light
  50. 07 Highlander Hybrid Differential, Transfer Case, and Transmission fluid changes
  51. Dead battery - fob issue???
  52. Highlander Hybrid P0300 P0302 P0304
  53. Help! HH 08 is getting 11mpg
  54. No energy screens
  55. grid charger on 07 hh
  56. 2006 Highlander "Rocks"
  57. Used 09 HiHy, 120,000 km... things to look for?
  58. New to Hybrids, question about Engine on 2007 HIHY
  59. Rosen head unit install on 2009 Highlander Hybrid
  60. Strut or strut/mount replacement
  61. NEW Highlander questions
  62. 2009 HiHy w/ P3011 - Battery Block 1 Becomes Weak
  63. 2010 Highlander Hybrid vs 2013 Gas Highlander
  64. 2006 Highlander Hybrid Battery Water damage?
  65. How is the battery cooled?
  66. Water on the floor?
  67. highlander hybrid o-n beach driving
  68. I love my hybrid Highlander BUT...
  69. HIHY, all seats down (to sleep) and AC on overnight, feasible?
  70. ABS light
  71. Tips on replacing oil on a Highlander Hybrid
  72. Service Manual for TCH
  73. Inverter Coolant Pump
  74. NHTSA probing 06 44,000 Toyota Highlander Hybrid crossovers over stall risk
  75. after-market car alarm for Highlander Hybrid
  76. 06 Highlander Inverter Fail 68,000miles
  77. Audio Nav System Replacement
  78. 06 HH tire reccomendation
  79. Can someone reccomend a good upholstery cleaner
  80. 06 Highlander Inverter Failure
  81. Bolt Patterns
  82. Is there a hack to manually turn on 4wd-i (or to take the "i" out of 4wd-i)?
  83. Looking into a toyota certified 2006 Highlander
  84. Inverter shoots craps at 105,000 miles
  85. GPS Misinformation on 2008 Highlander Hybrid
  86. navigation system in highlander
  87. B mode in Highlander Hybrid?
  88. Nearing 100,000
  89. Are the hybrid gas pedals involved in all this?
  90. Questions about EV speed
  91. hybrid inverter ?
  92. Replaced my stock 08 HiHy tires with 255/55/R19
  93. Odd behavior
  94. Solution to the frustrating 08 HiHy 19-inch tire problem
  95. 06 HH Touchscreen Repair
  96. Anyone have an 05-06 Highlander Hybrid with Nav?
  97. Changing Spark plugs on 06 HYhi
  98. Snow Tires for '09 HH Ltd.
  99. 2006 Highlander Hybrid VSC Alarms
  100. Anyone with a 2009 Highlander Hybrid w/NAV using the 5.1 LOADING.KWI file or LOCKPICK
  101. 2006 HH wheel fitment options?
  102. Computer Failure
  103. Custom Headlight Retro
  104. HH06 Cabin Filter Change
  105. What's your Lowest MPG?
  106. Thoughts on upgrading from 05 Highlander Hybrid to 09 Highlander Hybrid
  107. Newbie
  108. tires
  109. Tire options for 2008 HyHi.
  110. New Remote starter F/S anyone interested
  111. Lower mileage after new tires?
  112. Satellite install in 08 HyHi
  113. 06 Highlander Inverter Failure!
  114. All Weather Mats / Rear DVD ?s
  115. HH with 110,000 miles??
  116. A follow up from my earlier post(s).
  117. 2WD v 4WD
  118. New 06
  119. 2008 Oil Filter
  120. 30K service
  121. To Hybrid or not to Hybrid
  122. Happy with Highlander Hybrid?
  123. Camping Sleeping in the Highlander
  124. KW meter
  125. LED's
  126. hihy in accident & now i think i have a drag
  127. Service Campaign 90A (Steering link Replacement) Information
  128. econ mode questions
  129. Steering Link Safety Notice (aka Recall)
  130. Trailer towing MPG
  131. Dead Battery
  132. How to improve my MPG - Please help!
  133. Just Bought
  134. Strange odor
  135. Improving winter mpg
  136. Brand new 2008 DEAD BATTERY
  137. Highlander hybrid JBL audio system
  138. Tire Pressure Guages...
  139. Can't change the time!
  140. "06 used Highland Hybrid-67,000 miles-wise buy??
  141. New Highlander Hybrid arrived!
  142. Interesting Resource for information
  143. 2009 Highlander Hybrid
  144. HH Brakes
  145. Highlander 06- synthetic oil change?
  146. Engine for HH
  147. Regenerative Braking - A Problem I Think
  148. Increased Tire Wear????
  149. I4 Atkinson Cycle HH coming....??
  150. oil service message reset
  151. Confused about 'life time' mpg display
  152. News Reports on Highlander Hybrid
  153. Highlander technical details
  154. How I Avg 26.2mpg for over 3500 miles in my 08 HiHY
  155. Adding XM and Bluetooth to '06 HiHy
  156. Michelin Energy LX4 treadlife
  157. Highlander Hacks
  158. New to the forum
  159. Hypermiling and SUV max tire pressure
  160. Econ Mode
  161. Improve gas mileage, & useful modifications
  162. Main Hybrid Battery Died! Toyota HiHy '06
  163. MPG vs. driving technique?
  164. redirect question
  165. Poor mpg
  166. emf levels
  167. Traction control Mod ?
  168. 2008 HiHy recall
  169. Thinking of purchasing used Highlander Hybrid - advice
  170. Should I cruise on long drives to hypermile?
  171. Battery fully charged - LA to SF trip
  172. CHECK HYBRID SYSTEM warning !!
  173. Just bought new 08 Highlander Hybrid
  174. CD changer not accepting CDs..(trying first time)
  175. Dead battery in '06 Toyota HH from not driving it.
  176. Air pressure on goodyear integrity 225/65R17 ?
  177. Power outlets in a 2007 HiHy Limited ( 2WD)
  178. Duplicate key for $300 ?? WTF
  179. Need suggestions - Replace stock deck with a new one.
  180. When to do manufacturer suggested services?
  181. 2008 HiHy Traction Control
  182. Extended warranty - Buying a 2006 Highlander AWD
  183. Backup camera for 2006 Toyota HH
  184. Replacing Cabin Air Filter
  185. Which Generation DVD Nav does 2006 Hi Hy use?
  186. 4wd-i does not deliver what I expected
  187. GPS Problem-Can't enter address while car in motion ...any way around this?
  188. Cold weather mileage
  189. 2007 Highland Hybrid, how to reset maintenace required
  190. 12V Battery Question
  191. A question of rear heat
  192. CAUTION - A $0.05 part cost cost you PLENTY
  193. 2008 HiHy Bluetooth Install?
  194. How much max power really goes to the rear wheels?
  195. A silly question.....maybe.
  196. What is the lowest RR tire available for the HiHy?
  197. third row seat removal ?
  198. Eisenhower tunnel anyone
  199. Why so few Highlander Hybrids available?
  200. Adding Cold Air Intake
  201. 2008 HiHy - ECO button = Heretical Mode
  202. Wix + HiHy = Harmony?
  203. 2008 HyHi is a New Beast
  204. Nothing easier than this...
  205. 2008 HiHy Fuel System
  206. 2008 HiHY - Energy Flow Meter
  207. 2008 Highlander Hybrid Question
  208. Premature tire wear (Any TSb's)
  209. Electrical issue
  210. Update on 08 deliveries
  211. 40+ MPG Tank in my Highlander Hybrid 4WD
  212. Speed Sensor Failure
  213. Time for my first oil change - a question
  214. How do you hypermile in a Highlander?
  215. 12V Needed to Shift Transmission?
  216. Mouse!!!!!
  217. 2007 HiHy HP to the wheel's. Dyno?
  218. 2006 HiHy Traction Battery Failed
  219. 2008 Highlander Hybrid is on Toyota's site
  220. Brake Longetivity
  221. Removing roof-rack bars
  222. Total torque output
  223. My dealer's info on the 2008 HHys
  224. 4-wd system
  225. Standard Hybrid Tires are Dangerous!!!!!
  226. Took the Highlander Hybrid offroad again...
  227. Looking for confirmation (audio)
  228. The Anniversary
  229. 2006 HiHy and Scan Gauge?
  230. How accurate is the display fuel economy?
  231. O8 HH Towing Capacity - New information?
  232. Engine Block Heater for Highlander Hybrid
  233. 2006 Highlander MPG Read Out?
  234. Premium gas...?
  235. Engine Air Filter
  236. Has my ABS Failed?
  237. Lexus Hybrid Owners wanted to appear on Sundance Channel The Green
  238. After a month
  239. HiHy road trip - 3000 mi of Sand, Sun, Rain, Hail, Ice and Snow
  240. Any way to charge the main battery ??
  241. anyone have an aftremarket entertainment system?
  242. Lexus 400h: upload Address Book from Sprint Razr?
  243. Odd MPG goings on?
  244. Accessories question
  245. ABS Silonoid
  246. I was rear ended!
  247. Battery Level Indicator
  248. Took the plunge
  249. When is 2008 Highlander Available?
  250. Driving Videos!
