12V Needed to Shift Transmission?
Old Aug 3, 2007 | 02:54 PM
me2's Avatar
me2
Default 12V Needed to Shift Transmission?
I drained my 12V battery overnight (the dome lights stayed on because a door was ajar). I wanted to push the car a few feet to get easier access to my battery. With the key in the "on" position and brake depressed, I couldn't shift the gear to neutral. Everything was normal after I jump started the car and drove for a bit.
It just seems like a bad thing that you can't shift out of park if you have a dead battery or similar electrical failure.
Old Aug 3, 2007 | 03:29 PM
nomorebenz's Avatar
Default Re: 12V Needed to Shift Transmission?
I think, at this point, every vehicle is like that. No electric to release the brake pedal lock means you have to use the override. The override is under a cap located above the "P" on the shift column.
Old Aug 3, 2007 | 04:21 PM
me2's Avatar
me2
Ah, I never noticed that override before. I just tried it, and now it seems bad that you can shift to neutral w/o the key. But at least the steering column stays locked.
twolostminds
Nov 17, 2014 06:23 AM
Batson35
Jan 5, 2009 09:10 AM
kinsley1m
Sep 5, 2006 07:44 PM
Jason
May 16, 2005 05:16 PM
Jason
Hybrid & Related News
May 22, 2004 01:30 PM
