Yukon Hybrid Transmission HELP Needed
Old Jan 4, 2009 | 08:46 AM
Batson35's Avatar
Default Yukon Hybrid Transmission HELP Needed
Yesterday I mistakenly drained my transmission fluid and I have NO idea what the tranny fluid capacity is.
I cannot measure what came out and the manual lists multiple transmission with multiple capacities.
It's a 2008 Yukon can anyone help?
Old Jan 4, 2009 | 09:14 PM
Ed Blown Vert's Avatar
Default Re: Yukon Hybrid Transmission HELP Needed
I am not sure either, but I would put in 5 quarts and work your way to up 7. Checking as you go....
Old Jan 5, 2009 | 04:19 AM
Batson35's Avatar
Onstar said 10 qts...that has put me slightly over when checking hot an cold.
What an inexact science.
Any other thoughts.
Old Jan 5, 2009 | 07:52 AM
nicka's Avatar
Chevy Man
The Hybrid has a 2ML 70 Transmission. The info below is directly from the GM Dealer service guide. It looks like 10.5 Quarts is appropriate for what you did. Remember that not all of the fluid will drain with removal of the plug so if you put 10 quarts in you probably are slightly over. Also, be sure to use the GM fluid.
2ML 70 Drop Drain Plug Only- Approximate Capacity
9.93 liters
10.5 quarts
2ML 70 Drop Pan and Filter - Approximate Capacity
10.88 liters
11.5 quarts
2ML 70 Dry Transmission (Empty) - Approximate Capacity
12.30 liters
13 quarts
Old Jan 5, 2009 | 08:04 AM
Good to know. Thanks!
Old Jan 5, 2009 | 09:10 AM
Batson35's Avatar
WOW now that's what I am talking about...I did use Dextron VI...
How exact do I have to be I am over hot...not by a great deal not to the point it exceeds the bends in the dipstick.
Any thoughts?
twolostminds
Nov 17, 2014 06:23 AM
bbmotor
Jul 28, 2010 11:34 AM
ferrari
15
Sep 11, 2009 11:43 PM
Bweisbuch
Jan 16, 2009 07:34 PM
me2
Toyota Highlander Hybrid
Aug 3, 2007 04:21 PM
