Total torque output
Old Jul 12, 2007 | 07:41 PM
highlanderhybrid's Avatar
Default Total torque output
What is the total HP output from the Toyota Highlander Hybrid, I mean mine feels powerfull and all but 400 ft/lb torque seems a bit much, so how do I add the electric motor torque along with the gas?
Old Jul 12, 2007 | 08:12 PM
Mr. Kite's Avatar
Default Re: Total torque output
Where did you get 400 ft/lb torque? The HiHy has max 268 hp and max 212 ft-lbs. torque.
Old Jul 12, 2007 | 08:15 PM
Because I added torque from the electric and gas motor together
Old Jul 12, 2007 | 08:27 PM
Mr. Kite's Avatar
They do not provide that torque at the same rpms, so the combined max torque is 212 ft-lbs.
Old Jul 13, 2007 | 02:27 AM
ken1784's Avatar
http://pressroom.toyota.com/presstxt...erHybrid_s.pdf
The 212 ft-lbs max torque is by ICE only.
The max system power is 155 kW (ICE) + 45 kW (battery) = 200 kW or 268 HP (combined) .
We can see 252 ft-lbs torque from 200 kW at 5,600 rpm.
Ken@Japan
Old Jul 13, 2007 | 05:51 AM
Mr. Kite's Avatar
Ken@Japan
Thanks. I'm still having a hard time finding out what the maximum torque is. According to these specs, the electric motors alone combine for 343 lb.-ft. at low rpms.
http://www.toyota.com/highlander/specs_hybrid.html
I think highlanderhybrid was closer to the answer in the first place. I was the one who was wrong. Sorry.
Old Jul 13, 2007 | 11:39 PM
Don R's Avatar
Here are the torque curves for the Highlander Hybrids engine and motors:
Billyk
Apr 24, 2007 08:23 PM
JavaJ
Apr 17, 2007 11:06 PM
lakedude
Off Topic
Aug 22, 2006 10:49 PM
Adam_HybridCivic
Apr 19, 2006 07:43 PM
