2007 HiHy HP to the wheel's. Dyno?
Old Jul 29, 2007 | 05:46 PM
highlanderhybrid's Avatar
Default 2007 HiHy HP to the wheel's. Dyno?
Anybody know the real HP thats delivered to the wheel's on the 2007 Toyota Highlander Hybrid
Old Jul 29, 2007 | 07:54 PM
Don R's Avatar
Default Re: 2007 HiHy HP to the wheel's. Dyno?
The 2004 Prius was studied by Oak Ridge National Labs for the DOE. There was a 3.2 HP peak mechanical loss in the PSD. The Highlander has a similar Power Split Device so you can get an idea of the loss magnitude:
5.1 FINDINGS AND OBSERVATIONS
Initial vehicle-level data collected at ANL shows that the data acquisition scheme would provide adequate data to determine efficiencies of the basic hybrid electric drive system components such as the motor, generator, and inverter. It must reflect patterns and control schemes during various parts of a driving cycle. Sensor calibrations and equipment checks are needed to validate the data. This work is currently proceeding. Component-level testing at ORNL revealed that gearbox related friction losses were found to be significant. These losses are approximately 2.4 kW at a motor speed of 6000 rpm. The predominant loss of about 1.6 kW is associated with the main reduction gears and drive chain, while the motor, power split device, and generator yielded losses of about 0.8 kW. Gear train losses are primarily associated with oil splashing within the hybrid drive housing and oil slinging from the generator and motor rotors to provide needed lubrication and removal of excess heat. These losses, which are summarized in Table 5.1, were determined with the lubricating oil at or near room temperature (about 25°C). The tests also revealed that overall losses decreased about 20% when the temperature of the lubricating oil increased from 27 to 80°C. This finding indicates that total losses for the hybrid electric drive system equal approximately 1.9 kW at a lubricating oil temperature of 80°C.
Old Jul 29, 2007 | 09:54 PM
Thank you! Also I understand a bit about the transmission, but as I understand it for the V6 it only has 1 gear? How much power is the V6 able to provide, nearly all of it's 212 HP? I just don't understand still how it can have 1 gear and still have fast acceleration at 70 MPH. Also without the limiter what do you think the top speed stock would be? Thanks
Vic Doucette
Aug 29, 2015 05:30 PM
Curated Content Editor
May 8, 2014 05:00 AM
jelsea
May 8, 2013 01:11 PM
mnsweeps
Apr 6, 2008 11:21 AM
SomervillePrius
Dec 26, 2005 10:07 AM
