Newbie
Old May 30, 2009 | 01:55 PM
ANYWHR's Avatar
Question Newbie
We just picked up our 2009 Limited. So far so good, I am getting 24.4mpg mixed highway/city.
I have a question, we live in some hilly areas and would like to use the "B" selection on the shifter. My question is will it hurt the vehicle to use this? The salesman was not to sure.
Thanks for the feedback.
Old May 30, 2009 | 04:02 PM
Phil Kulak's Avatar
Default Re: Newbie
The "B" just makes the engine turn with the valves nearly closed when you let off the gas. It's engine braking, and not totally necessary unless you're going down a long hill. If you use it too much I'd assume that it could hurt your regenerative braking, though if you don't use it when you should it could hurt your brakes.
Old Jun 1, 2009 | 08:26 AM
andybl's Avatar
Default Re: Newbie
I use the B setting going down long mountian passes when the traction battery is fully chanrged. Under this condition the computer turns off the regen braking. This saves on brake wear.
Old Jun 1, 2009 | 09:28 AM
PineywoodsPete's Avatar
Default Re: Newbie
Toyota wouldn't have added this feature if it would hurt the vehicle in any way. The only thing it will hurt is your FE a bit if left in this position without a full traction battery, because some regenerative braking (hybrid "free lunch"!) is replaced partially by engine drag.
Pete
kirby
Introductions
Jun 23, 2005 12:36 PM
kirby
Jun 20, 2005 09:47 PM
plopez
Jun 9, 2005 05:02 AM
clayk
May 7, 2005 09:03 PM
