High Idle in Winter
Old Feb 21, 2014 | 04:47 AM
MTL_HiHy's Avatar
Default High Idle in Winter
Just out of curiosity is anyone experiencing an unusual high idle in winter when the defrost (AC) is on. It seems like the idle jumps up quite a bit when I set it on that but if I turn the fan off at a stoplight the engine stops right away and goes into EV mode as I would expect. Not sure if this is normal or if maybe there is excessive current draw or a problem with my traction battery causing this higher than normal idle.
Old May 17, 2014 | 02:27 AM
MTL_HiHy's Avatar
Default Re: High Idle in Winter
After some troubleshooting it appears the high idle may be related to disconnecting the 12v battery (there is a throttle relearn procedure that is supposed to be done after that......can be done with mini VCI). It may also have been my issue with the traction battery so hard to tell exactly the issue at this point. In any case now that the traction battery is fixed the issue has not returned at all.
IslandCre8tion
Feb 17, 2015 06:10 PM
CT Yankee
10
Aug 11, 2009 01:13 PM
Geoff
High Mileage Vehicles
Aug 9, 2009 03:09 AM
plopez
Jul 10, 2005 10:09 AM
