Dead battery - fob issue???
Old Sep 3, 2013 | 12:45 PM
cpreusse12207's Avatar
Default Dead battery - fob issue???
Does it drain the 12V battery to leave a fob inside a Highlander Hybrid that is entirely powered OFF?
I drive a 2009 HH and can't tell you how many times in the past 2 months that I have come outside to a dead car battery. Original everything - nothing has been replaced. No other problems with HH except the 12V.
Last week I took the HH to Toyota for a battery check. The test results showed the battery was "OK" - about 50% life left in it. They did not recommend that I replace it. BUT, i did drive the car 20 miles on the highway to get to the Toyota dealership -- could the readings have been wrong given that the car had just been run hard?
I am diligent in making sure that nothing else is running when I power off the car. No interior lights. No doors ajar. Nothing.
I have however found that the car battery is dead on the mornings after i've left the fob inside the car all night long.
The only thing I can figure is that by leaving the fob inside the car at night, the 12V battery is drawing a very slight undectable charge that is draining the 12V (which is already getting old and in a weakened state) -- is that even physically possible? If so, I guess I'll have to keep the fob with me at all times.
Obviously we live in a very safe neighborhood so I don't worry that anyone will steal the car in the middle of the night. But i worry that i'm wearing thin my welcome with neighbors to CONSTANTLY ask for jumpstarts.
Thanks for any advice you can provide.
Old Sep 5, 2013 | 09:52 PM
go-part's Avatar
Former Vendor
Old Sep 3, 2014 | 09:45 AM
MTL_HiHy's Avatar
Default Re: Dead battery - fob issue???
Two things:
1) Don't leave the fob in the car (vehicle's onboard computers "wake up" with fob nearby)
2) Anything below 60% battery life is toast, you should replace it.
You can just hook up the vehicle to a smart charger nightly but that gets to be a bit tedious after a while.
haroldo
Nov 14, 2010 02:44 PM
zebrajeb
May 14, 2010 04:44 PM
infael
Feb 26, 2010 11:56 AM
LEAKYTCH
Jul 29, 2009 08:44 PM
