PDA
View Full Version : HCH II-Specific Discussions
Pages : 1 [2] 3 4 5 6 7 8 9
  1. 2006 Civic Hybrid Engine unresponsive for a few sec while driving
  2. Ima battery install
  3. 12V battery and IMA not charging
  4. Warranty on 2nd replacement IMA battery?
  5. Need help diagnosing IMA/battery troubles
  6. 2006 Honda Civic Hybrid IPU Fan Speed Control Help Needed
  7. Reconditioning DIY 2006 CIVIC HYBRID
  8. HCH2 EGR Port Cleaning - HOWTO
  9. Spark Plug Details for 2006 HCH II
  10. Please help, why is my car bogging?!
  11. 07 HCII, CVT Shudder from stop, New IMA, DC/DC, Tranny fluid=13Kmiles old?
  12. Transmission Mount Problems
  13. Installing a backup camera
  14. 06 FM Radio doesn't get good reception
  15. Service Manual for HCH
  16. HCH in Singapore? Should I avoid it?
  17. Another IMA and Warranty Extension Question MA vs. FL
  18. IMA and Battery Light
  19. New to the forum new to hybrids
  20. 2006 Honda Civic Hybrid Starting issues.
  21. Grid Charger for Dummies
  22. POA7F on 2007 with 82k miles, am I out of warranty
  23. Help me out here - Honda Civic Hybrid 2007 problems
  24. All ready for the weekend.
  25. 2008 HCH IMA Warranty Ext IL
  26. 06-11 Civic Hybrid - Water leak beneath the car (near cat)
  27. Can't find my front jacking bracket
  28. 06 Civic Hybrid shuts down while driving
  29. 2009-2011 Honda Civic Hybrid Battery Warranty Extension
  30. A question regarding IMA sticks
  31. Loud Valves 140k?
  32. IMA and CVT Shutter Problems
  33. Recal question on 4 mile hill.
  34. Valve Cover Gasket
  35. code reader
  36. Purchase advice 2006 with just 30k miles
  37. I got my IMA battery replaced for the second time
  38. Spark plug change
  39. Security system
  40. CVT jerky
  41. Replacing Transmission and Engine Mounts?
  42. Back-up car
  43. MPG Gauge
  44. Just bought car; looks like 12v or IMA battery failure!
  45. Replaced ima battery
  46. CVT Shutter problem fix
  47. IMA Battery Question
  48. IMA dead after reconditioning
  49. Fuel Pressure?
  50. Are my valves slapping?
  51. Whats this engine rattle? Video included
  52. 2006 HCH II AC stopped working
  53. Does audio system affect IMA ?
  54. Navigation button not working
  55. normal state of charge
  56. Any battery stick supplier for the Civic Hybrid?
  57. What is wrong with my 2010 HCHII, horrifying fuel economy.
  58. New to me 2007 Civic
  59. 9 po codes!
  60. Autostop not engaging
  61. How many here user a gird charger for their Honda Civic Hybrid Gen II?
  62. Disabling HCH-II HCH2 IMA
  63. 12V Battery Light - Not Charging ?
  64. 12V Battery Indicator Window
  65. 12V battery vampire leak
  66. Used part sources?
  67. IMA battery replacement longevity
  68. HCH-II - Electric power steering warranty extension
  69. Broken Engine Mounts on HCH II (2006)
  70. IMA lights went on, warranty replacement approved, but then they went off - what now?
  71. Just received a Class action lawsuit letter from Honda Canada
  72. Almost 6 Years
  73. advice on ac repair, or just sell my 2007 hch
  74. '09 Big ticket repair - and it's not the battery
  75. My HCHII IMA troubles writeup
  76. Two IMA battery replacements in 7 months
  77. 2006 Honda Civic Hybrid Cat Converter
  78. I just lost 5mpg going to a 5 pound lighter volk wheels how is this possible
  79. HCH 09 IMA warranty?
  80. how many cooling fans have the hchII?
  81. Broken motor mount
  82. Will a 07-09 transmission fit in my 06 hybrid
  83. Cvt transmission failure help
  84. 2006 HCH Recals everyday morning under 30 degF & gas mileage is between 34 to 38 MPG
  85. AUTOSTOP kills the legal stops,
  86. Wich car is best hchii 2006 or 2011? Main differences
  87. Extra Cells or an entire Pack + Thank you + recap of my car
  88. 2011 HCHII IMA Light Questions
  89. Any advice on breaking in a new battery?
  90. accident, spare parts
  91. HCH II Test Drive
  92. Many thanks to all who post
  93. Warranty Extension: Uneven or Rapid Tire Wear
  94. 2008 Honda Civic Hybrid IMA and Check Engine lights on then both turned off
  95. 12V Battery Replacement; Aftermarket AC Delco Option
  96. Sudden Change in SOC behavior; 2007 HCHII
  97. Traded 2008 HCH for a 2013 TCH
  98. Problems with 2006 HCH with new IMA battery.
  99. smaller wheels on a 2006 HCH II
  100. 2009 HCH - awful fuel economy. What to try next?
  101. 2008 HCH just purchased and IMA light comes on
  102. 2003 hch ima problem
  103. Now my transmission CVT is dead as well at 175,000 miles. $5,000 to replace.
  104. time for battery replacement?
  105. 2007 HCH died on the freeway tonight
  106. Brake Master Cylinder Servo?
  107. Where's the fire?
  108. I'm brand new to hybrids & found a great deal on an 06 Civic, what do I need to know?
  109. OBD code readers for HCHII - What do you use?
  110. Honda Dealer upgrading 2006 Civic Hybrid to Lithium Battery Under Warrenty
  111. Battery discharge other than IMA issue?
  112. Need Assistance - IMA light
  113. any way to replace/fail battery under warranty?
  114. Do I Really need a new ECU?
  115. Sucessfully Reconditioning an IMA Battery Pack
  116. HCH 2007 IMA Battery
  117. Battery replaced with no IMA light!
  118. 2006 Civic Hybrid Warranty Question
  119. IMA light & Check engine light question
  120. IMA Battery Cooling
  121. Advice Needed
  122. New to me 2006 Civic Hybrid
  123. Replacement IMA battery warranty
  124. 06 HCHII @ 220k
  125. Does 12v battery affect IMA battery?
  126. Anyone added bluetooth to 2007 HCH?
  127. 2006 Civic Hybrid battery issues
  128. '09 HCH - Reduced Economy
  129. Using 12V battery more often during startup - 2008 HCH
  130. 07 Civic Needs new IMA
  131. 2009 HCH getting poor mileage
  132. Well it has happen to me- Battery death
  133. Advice - Buy a 2009 HCH or not?
  134. 2006 Honda Civic Hybrid *Need New IMA*
  135. '07 HCH used value in CA
  136. 2008 replacement tire suggestions
  137. Problems after battery replacement
  138. NY IMA Battery warranty
  139. Battery Replaced in 2007 HCH w/ 67k mi
  140. bye bye!
  141. P0701?
  142. warranty for a replacement battery
  143. How to bypass HCH-II high voltage battery
  144. Do I keep my Extended Warranty?
  145. Hybrid Computer Replacement
  146. Looking for best software update
  147. 2008 HCH electrically weirdness...
  148. Honda Civic Hybrid 2009 - IMA Light Question?
  149. Grinding???
  150. How's your replacement IMA Battery holding up?
  151. At 48k miles...should I do "recommended service"?
  152. Well, that was easier than expected...
  153. HCHII 105,000 Mile maintenance?
  154. IMA Finally Replaced
  155. Looking for HCHII battery sticks- bad OK
  156. 06 HCH died on start- reset- works fine now?
  157. navigation software problem
  158. tpms oddity
  159. does anyone have a solution for rear tire wear?
  160. Different tyres on the hybrid
  161. any non-American using Duracool / HC12
  162. selling to CarMax
  163. 2007 HCHII brake replacement
  164. Weird fuel consumption behavior Civic Hybrid 2006
  165. 2007 Civic Hybrid CVT Fluid Change Flush DIY Very Easy Applies to 2006-2011
  166. Adios HCH2
  167. Rear control arms- which cars are compatable?
  168. What's your MPG at 70 MPG?
  169. Hot tip- check your trunk for moisture
  170. Replace 12v battery myself?
  171. swapped IMA battery- car is totally DEAD
  172. Trunk liner for sale near San Diego – $50
  173. How many miles on your original IMA battery with (IMA light on)
  174. Help getting IMA replaced under warranty
  175. Update to Civic Si Rear Sway Bar?
  176. Burnt Clutch Smell After Climbing Very Steep Hills
  177. Saying goodbye to our '08
  178. Complete Electrical Failure
  179. Switching to a higher viscocity oil after 100k?
  180. Unresponsive accelerator pedal, starting on slope
  181. NHTSA is looking into our cars
  182. DC to DC Converter failure???
  183. '09 for sale, 39K miles, new IMA, leather, NAV
  184. Broken mirror turn signal. Need help.
  185. New HCH II Owner
  186. Feb 11 Looming, Should we opt out?
  187. New IMA battery and new software -- is this behavior normal?
  188. Petition to AGs on class action settlement
  189. Is there a Scangauge Parameter for:
  190. Used battery installed- no improvement in MPG
  191. Just purchased a 2007 HCH-2
  192. Installed Used battery today
  193. 12V Battery Replacement Detailed
  194. Does the 2009 HCH battery fit on 2006 ?
  195. Efficacy of grid charger on failing IMA battery
  196. Battery starting to go?
  197. Spark Plugs for Sale
  198. New ScanGauge in the mail: ideas for set-up wanted
  199. Long term storage and junkyard battery
  200. code P0A7F - DIY battery replacement?
  201. I love 06 HCH== what's wrong with me.
  202. DontSettleWithHonda.org RE: '06-'06 HCHs
  203. Anybody heard of yet another battery firmware update?
  204. How to scan for codes in my 2007 HCH
  205. 2007 Civic gone, 2012 Volt took its place
  206. 2010 with 18k and bad battery
  207. IMA Battery Warranty Replacement
  208. Spark Plug Wires
  209. Fuel tank warranty extension
  210. My first 'no electrical assist and near miss' adventure
  211. New to me HCH
  212. Honda talking to SAE on 2012 HCH powertrain
  213. What's the danger of riding this with the IMA and check engine warning?
  214. 3 Year Anniversary
  215. IMA replacement for out-of-warranty 2006 HCH
  216. Transmission noise and right wheel grinding
  217. Daily recalls until scheduling an appointment with the dealer?
  218. My IMA Replacement Story
  219. Should I sell my hybrid? Dealer wants to buy.
  220. IMA Battery Finally Replaced
  221. Changing Spark Plugs In HCHII?
  222. 06 HCHIII @ 180k
  223. Here wh go...
  224. Just won battery lotto
  225. 2007 HCH Maintenance Questions
  226. Recalibration Every Day
  227. Has this happened to anyone elses 06HCH?
  228. Which 12v battery?
  229. Going hat in hand for software update
  230. Another battery problem and some questions
  231. Ecopia ep100
  232. Time for new tires?
  233. 2007 certified hch
  234. Battery refurbish in process - IMAX B6
  235. My turn for IMA problems – advice needed!
  236. Difficulties cranking after the weekend
  237. IMA & 12V battery problem
  238. how much for rear control arm TSB ?
  239. I installed a lawn mower battery- works great
  240. Honda civic hybrid only getting 33mpg?
  241. Honda civic hybrid only getting 33mpg?
  242. Odd that the HCH II does not remember its IMA state
  243. keep 2007 hchii or get the new 2012 vw passat tdi
  244. Help...Water in trunk after rainstorm
  245. HCH-III On Order
  246. Intermittent no assist
  247. aux jack problem 2006 civic
  248. Need to replace garbage Dunlop tires after 25,000 on 09 -- Recommendations?
  249. HCH2 2009 very poor mileage..help please..
  250. How much the recent recall is important(Voltage Converter) ?
