Battery starting to go?
Old Jan 11, 2012 | 11:48 AM
AndySmith's Avatar
Default Battery starting to go?
All,
I have an 07 hybrid and the battery is starting to do SOC daily recals (recalls?). Is this a failing battery in everyone's experience?
Thanks.
Old Jan 11, 2012 | 12:47 PM
Default Re: Battery starting to go?
Have you had the recalls performed on your IMA? If not it would probably help with the recal situation? It manages the SOC much better. H
Old Jan 11, 2012 | 12:49 PM
AndySmith's Avatar
Yes, it's had all the updates.
Old Jan 11, 2012 | 04:22 PM
navguy12's Avatar
Yes.
Old Jan 16, 2012 | 01:28 PM
AndySmith's Avatar
Well I took it to the dealer and they installed a new software update on it. I wasn't aware there was another one since "the" hated update.
It didn't have an SOC recal for 2 days, but did once this morning. I'm going to continue to monitor it.
Old Jan 16, 2012 | 02:06 PM
It will help, but the pack may be on its way out like many HCH2's. If you only have recal's on occasion then a person can deal with it. The odd recal is not a big issue, I think. I don't think my car has ever had one? Touch wood! H
Old Jan 16, 2012 | 04:36 PM
reagle's Avatar
I wonder if that's the same update I got in December. They said I was missing one. Still getting recals though
Old Jan 20, 2012 | 12:45 PM
hunter44102's Avatar
Recals indicate a battery problem almost certainly. Once I replaced my 'recal' battery, I have not had a single re-cal in months!! Not once, and I've gone through every type of temperature and weather and driving conditions, city/highway/stop and go.
Old Jan 20, 2012 | 12:53 PM
reagle's Avatar
We have to be careful to differentiate recals from normal battery SOC depletion. If I am constantly loading the pack, I see it drop down to 2, but then instead of forced regen to full it climbs to 4 bars and then allows some assist and autostop. While in recal, it drops, then will not let you use Assists or autostop until it 's all the way to full. I think one is a problem, the other one may be normal operation
Old Jan 20, 2012 | 02:56 PM
I had re-cals - drop from 4 bars, then no assist until it charged back up. i was up to 3-4 a day on a 60mi round trip commute. Now i get none!
