Can't find my front jacking bracket
Old Oct 10, 2015 | 07:36 AM
Valalvax's Avatar
Default Can't find my front jacking bracket
Attempting to do my first ever oil change (and soon a transmission flush) but I can't find the dang front jacking bracket, the pictures in the service manual do no good, they show dead center and there's nothing but plastic dead center... Just behind the tow hook seems like a possible point, but I don't know... the side jack points don't seem wide enough to fit a jack AND jackstand beside each other without seriously risking a drop
*edit* finally found it, dead center as the manual said... jacked my car as high as the jack would go, and the passenger side jack stand slide into place barely, but the drivers side wouldn't fit
is there anywhere else I can jack it? Because I definitely cannot get the jackstand underneath the jack point with the jack there, tried a hundred ways and even with only a millimeter of the jack making contact the jackstand wouldn't even TOUCH it (much less make a stable work area)
Old Oct 10, 2015 | 02:14 PM
Default Re: Can't find my front jacking bracket
I use ramps.
Old Oct 11, 2015 | 01:13 AM
sterling388's Avatar
Ditto. Ramps are a time saver....
Old Oct 11, 2015 | 01:36 PM
Valalvax's Avatar
Used a block of wood, done and done...
Though I'm probably gonna exchange the jack stands and try to get shorter ones...
rodbuilder
Feb 18, 2015 03:04 PM
rodbuilder
Dec 14, 2014 08:13 PM
pb5927317
Dec 3, 2007 05:32 PM
dbennettya
Nov 25, 2006 09:36 AM
nysebull
Sep 9, 2005 02:08 PM
