HCH2 EGR Port Cleaning - HOWTO
Old Mar 15, 2016 | 09:43 PM
Default HCH2 EGR Port Cleaning - HOWTO
If one or more of the EGR ports get plugged, rough running or light pinging can be heard at cruise and light throttle settings. Clean as follows:
Detach/loosen hose at airbox:
https://www.dropbox.com/s/1tb7cch1le...0Hose.jpg?dl=0
You can likely leave this end of the hose connected and work the whole thing out, easier to reconnect only at the airbox:
https://www.dropbox.com/s/syuy5b78bl...0Hose.jpg?dl=0
Remove Inlet Plenum, two bolts, lift rear to disengage posts from grommets:
https://www.dropbox.com/s/cqg10h9zf2...mmets.jpg?dl=0
Remove Bracket, 2 bolts, clip, hose clamp and hose (beware small amount of coolant loss; plenum grommets in yellow):
https://www.dropbox.com/s/23vkellc90...ellow.jpg?dl=0
Remove EGR Ports cover;
https://www.dropbox.com/s/s9lfzsv5uq...cover.jpg?dl=0
Clean Cover:
https://www.dropbox.com/s/u2ez54z6u6...cover.jpg?dl=0
Carefully clean gasket:
https://www.dropbox.com/s/xik5j3dzox...place.jpg?dl=0
Clean ports in Red, don't contaminate coolant in yellow:
https://www.dropbox.com/s/g5xu91weux...ellow.jpg?dl=0
I used 80psi compressed air to blow out all carbon deposits.
Old Mar 16, 2016 | 01:46 PM
Valalvax's Avatar
Default Re: HCH2 EGR Port Cleaning - HOWTO
Good write-up, the ChrisFix's video on youtube leaves much to be desired,
why disconnect the airhose at the airbox? I only disconnect on the manifold
Old Mar 16, 2016 | 01:51 PM
It may not be necessary. I had a lot easier time manipulating it with it disconnected from the air box.
Old Mar 16, 2016 | 01:52 PM
Valalvax's Avatar
When I do it, I remove the bolts, lift up on it, then twist it and it slides off
Putting it back on is the hard part
Old Mar 16, 2016 | 01:56 PM
You just jogged my memory.
I disconnected it only at the airbox and fed it through. At assembly, I fed it back through, re-attached at the airbox, mounted plenum and rotated hose as needed.
This was a year and a half ago, and my mid-forties brain is leaking.
Editing post.
Old Mar 16, 2016 | 02:02 PM
Valalvax's Avatar
That /does/ sound like a job...
*edit* Went to go check it because your post reminded me that was on my to-do list... couldn't find the socket bit for my impact... far too lazy to use a regular wrench now that I have the impact
Old Mar 16, 2016 | 02:07 PM
Oh... you're telling me... bought a cordless impact and OMFG... what took me so long to get one of these? I used it during motor mount and Cat replacement. Joy.
Old Mar 16, 2016 | 07:03 PM
ckendall37's Avatar
Excellent info. Thanks for posting!
Old Jul 16, 2016 | 11:09 PM
HybridGates's Avatar
Finally did this, I had a 4mm thick crusty deposit I had to cut off with a screw driver. Thicker in other parts. I did my best to not get it in holes by using a vacuum, but over all I got it all out. I try my best to clean that inner port where it goes down, but A screw driver and brush can only go so far.
Old Jul 27, 2016 | 10:11 PM
Bazzetta's Avatar
Pictures do not display. Is it me or the forum?
