Complete Electrical Failure
Old Mar 19, 2012 | 01:58 PM
dmw16's Avatar
Default Complete Electrical Failure
This morning I drove my 2007 Civic Hybrid for the first time in about 2 weeks.
The car started with a little hesitation, but I figured that was from sitting for 2 weeks so I thought nothing of it. I then drove about 10 minutes to the gas station and filled up.
When I went to start the car again nothing but ticking. The dash lights struggled to come on. I turned off the headlights and tried again. Still no luck. After 3 more tries the car finally turned over, but there wasn't enough power to run the power steering or power brakes or the headlights or hazard lights.
I managed to limp about 2 miles before the car completely died.
The car was towed back to my house and I put a multimeter on the batteries and it read 6.2V which would suggest the battery is not charging for whatever reason.
Up to this point I've had no issues with the car. I bought it last July with 120,800 miles and I've put about 21k on it myself.
Could this be as simple as needing a new battery or is a piece of the charging system broken? The battery looks really gross. I didn't have time to look for a date of mfg or anything.
I read about the DC/DC converter recall, but I don't know if the car has been seen for that since the recall came out before I owned it.
Thanks in advance.
Old Mar 20, 2012 | 09:25 AM
Hybrid Captain's Avatar
Piloti di Hybridi
Default Re: Complete Electrical Failure
Hi,
The 12 volt battery is "Kaput".
Replace the 12 volt battery with a quality replacement. Clean all connections and make sure the cables are sound. Should be good to go after that.
Old Mar 20, 2012 | 10:37 AM
hchiiluv's Avatar
I second that...get a new battery. By the way never listen to the radio with the car off, but with the power on, and the lights. I had drained the little battery, and the traction in back. I got it started, without a jump but dash lights were on, and the car ran badly for a view minutes till the little battery got back some volts. Never did that again.
makingendsmeet
Aug 21, 2014 11:28 AM
WVGasGuy
Introductions
May 26, 2006 11:05 AM
Cityscapex5
Mar 28, 2006 08:54 PM
Jason
Hybrid & Related News
21
Aug 20, 2005 05:56 PM
