PDA
View Full Version : HCH II-Specific Discussions
Pages : [1] 2 3 4 5 6 7 8 9
  1. CVT Valve Boby disassembly pictures
  2. S. Keith i'm in need of your expert opinon....
  3. CVT external filter teardown disassembly pictures
  4. 12v Battery Sizes
  5. Loud rattle with light acceleration
  6. Frequent recalibration with battery recently changed
  7. O2 Sensor for 2nd (Rear) Catalytic Converter
  8. Question about maximum time for grid charging.
  9. Torque sequence for CVT pan bolts needed.
  10. Honda Civic 2008 Hybrid G2 IMA Issues
  11. My 12v Battery discharges even when driving
  12. 2009 with P0A3F
  13. Replacement battery cells, recommendations
  14. 2006 HCH - New Hybrid Battery but MPG is low & system acts weird
  15. Swapping one bad pair of sticks with brand new ones.
  16. 07 HCH; loss of coolant, overheating, white smoke
  17. IPU fan running for long periods duriing highway driving
  18. 2006 Civic Hybrid IMA+CEL light permanently on
  19. Question about checking CVT fluid level.
  20. Help needed with grid charging/discharging.
  21. Erratic VPWR / Intermittent CODE P1575
  22. 2010 Needs new BCM
  23. 2007 HCH No-Start Condition
  24. A/C not working
  25. dc-dc coverter input voltage? output voltage?
  26. how to diagnose my IMA problem
  27. Brake & abs light on
  28. IMA system not working with no codes
  29. HCH2 Battery voltage taps safe real time monitoring.
  30. 06 ABS & BRAKE SYSTEM yello lights on
  31. 2008 honda civic hybrid
  32. 2006 civic auto stop
  33. Disabled IMA, charges, then fries dc-dc?
  34. HCH 2007 keeps beeping after turning car off!
  35. battery pack capacity - grid charging
  36. Installing used AC compressor
  37. help 2008 honda civic hybrid red 12v battery and ima
  38. HCH2 grid charging - battery fan PWM control not working
  39. IMA battery replacement
  40. is easy to fix CROSS POSTED ??
  41. Hchiii ima battery in hchii ? Will this work
  42. MPG going down HELP
  43. Auto climate control stuck on ??
  44. 2009 Civic Hybrid iMA HV/12V and Other problems
  45. How to remove antenna
  46. Hybrid battery issues, car works fine after resetting codes.
  47. 2006 civic p0a3f
  48. Anyone successfully upkept their IMA battery after replacing?
  49. 2009 HCH - Cooling Crises, Heating Headaches, and Diagnostic Dilemmas
  50. '07 Bought @ 212k M. Reccomendations w/ IMA Grid Charger and/or Replacement
  51. 2006 HCH 12V Accessory battery won't charge. Gauges flashing and car dies @20mins dri
  52. Ima battery cell voltages
  53. PA0E1 and P1448
  54. AC refrigerant oil
  55. Old Battery pack worth and P0A7F(03) with new Pack
  56. Is cat converter stealing a thing?
  57. civic hybrid 2010 4 leds apocalypse
  58. Navigation and radio codes
  59. Transmission fluid
  60. Finally joined the P0A7F club
  61. F/S - Left Tie Rod End
  62. 2006 HCH battery temperature sensor
  63. The Hybrid is Dead, Long Live the Hybrid!
  64. Valve adjustment
  65. Which stick is #11?
  66. 11 months after initial grid charge, battery stays around 3/4
  67. No power at all after someone ‘helped’ jump start hch2
  68. Error P1575 (three lights on)
  69. 12V Battery Not Charging
  70. Bridgestone Ecopia
  71. IMA failure?
  72. Location of the Motor Current Sensor?
  73. P0A7F - but only sometimes?
  74. Problem with electric power steering
  75. Do I need a new IPU fan?
  76. A Compilation of Maintenance Experiences
  77. New 12v battery on HCH 2007 keeps dying
  78. HCH 2007, new battery discharging
  79. IMA battery completely discharging overnight. What are my options?
  80. 2006 HCH no start in warm weather
  81. Turning friction sound and 1300rpm rattle
  82. Appropriate and economic scan tool for HCH 2008
  83. Cut close to engine air filter
  84. fuel pump
  85. Oil Leaks
  86. Urgent--need to know what would happen swapping 2008 HCH2 IMA battery with a 2009
  87. Should I grid charge healthy battery
  88. 2006 HCH CVT pinout
  89. Civic 07 batterie restauration
  90. ABS pinout?
  91. Honda Civic 2009 - U1205 and U0110 Codes
  92. P1575 and P0AE1 codes after grid charging
  93. Failing battery, replaced it, now Other issues
  94. Help please. Camry 2015 USA hybrid
  95. AC On causing 12v light, hybrid system shut down
  96. need help reconditioning battery pack for 2007 hch2
  97. Where to buy large volume CVT fluid? 12qt
  98. 2007 Timing chain replacement
  99. Reliable source for battery sticks /cells
  100. Replaced cat converter but still having no power
  101. Charging system help!
  102. Transmission Issues (dying?)
  103. Will a Bumblebee Performance replacement IMA battery have better MPG than Standard?
  104. 07hch fuse #1 blown
  105. P0A27 error.
  106. Help Diagnosing Stall Issue
  107. What is this steering sound? (video link)
  108. Newbie looking at ‘08 HCH
  109. AC Pressure charge question.
  110. 2008 honda civic hybrid
  111. Solar charging the IMA pack
  112. 12v Not Charging, New IMA pack, new 12v, new DcDc Converter
  113. With new ima battery the 100A fuse gone
  114. A/C problems 8th gen Hybrid
  115. Seat belt buckle
  116. Oil pan gasket replacement advice 06 HCH
  117. loss of power when accelerating
  118. Went from 42 to 46 MPG with some hypermiling techniques!
  119. 2008 HCH struggling up 18% grade. Normal or is my CVT failing?
  120. Comfortable tire and brake pad recommendations?
  121. 2009 HCH2 ticking during idle
  122. 2008 Civic Hybrid brake servo replacement or repair?
  123. AC Issue works on belt but not electronically
  124. AC freezes up in hot weather.
  125. Battery "bounce back" after discharge during "refurbish" cycle.
  126. 2009 With IMA issues
  127. Replacing engine mount
  128. Air and cabin filters
  129. Building a HCHII grid charger
  130. Changing spark plugs when?
  131. Dying or nearly Dead IMA?
  132. Battery Rebuild Experience
  133. Got an oddity for ya'll...... No surprise I'm sure...
  134. IMA Battery Usable Capacity -CONFIRM
  135. Let's talk about the window defroster and autostop
  136. Parting out 2006 Magnetic Blue Pearl
  137. Looking for recommendations on battery pack replacement
  138. Need IMA battery testing diagram
  139. Using Honda CR-Z or Honda Fit 3rd Gen Hybrid Sticks for HCH-2
  140. Fuel Filter?
  141. Should I buy, 08 HCH2 183k miles, for $2500?
  142. "Brake System" light on
  143. Pinging
  144. Strong Exhaust Odor on Cold Start
  145. 2007 HCH EPS issue
  146. AC and fans goes weakrandomly, only in hot weather.
  147. A bit confused about how it charges so quick
  148. Cylinder missfire fix or cat converter replacement?
  149. HCH-II PWM Frequency - Grid charger in the making
  150. IMA Diagnostic Codes Mystery
  151. P1448 with good battery and fan
  152. Cvt fluid alternative?
  153. 12 V battery light on? Little battery not charging.
  154. Lost key
  155. Grid Charger Build
  156. 2008 Civic Hybrid grunts, groans, and struggles onto the freeway
  157. 12v battery comes on, needs a compression start to "fix"
  158. IMA Battery Problems after Dead 12v Battery Replacement
  159. grid charging time?
  160. Just got 07 civic hybrid. Might be problematic ?
  161. 30 mpg with Hybrid 2008
  162. IMA Battery - Replaced twice? Thrice?
  163. Metallic Engine Knocking - 06 Civic Hybrid 192k
  164. Healthy IMA self-discharge rate?
  165. Considering buying a 2006 Civic Hybrid with 120k miles
  166. HCH II BCM Cable Balance
  167. 2008 honda civic hybrid battery high voltage ,but no assist
  168. Do I put money into my '06 HCH II w/95k miles
  169. IMA light; jerkiness; engine error codes
  170. IMA light after replacing my hybrid battery
  171. Battery Pack "Reconditioned"
  172. New PCM, no more Auto Stop
  173. 06 205,000 miles original CVT "GAP" issue
  174. Building a grid charger to try to save a battery, have some questions.
  175. ECM possible issues & how to diagnose
  176. Question on indentifying GOOD/BAD cells module sticks reconditioning
  177. Grid Charger: max voltage when charging?
  178. 2009 HONDA IMA battery vs 2007 HONDA IMA battery Honda civics changes made?
  179. P0171 and across the board misfires (P0300-P0304)
  180. Measuring voltage between BCM connector terminals
  181. Clunk and Jerk while Braking in Reverse 2007 HCHII
  182. Should I buy a 2006 HCH2??
  183. 2006 Civic Hybrid Won't Turnover
  184. Difference Between 2003 and 2006?
  185. 200k HCH any good
  186. New HCHII owner, several questions
  187. Funny issue, 3 codes come up, but go away after restarting car a few times.
  188. Wanting to squeeze more life out of a dying battery
  189. Controlling the HCH II IPU Fan
  190. 35 mpg?
  191. DIY IMA pack replacement
  192. What is the Serpentine Belt Routing for HCH II on the 2009
  193. Engine Hesitation around 3000RPM - HCH II 2006
  194. Anyone else using a ScanGauge?
  195. New DC to DC converter needs reprogramming?
  196. AC Recharge Question!
  197. HCH II battery terminal reads 0V but cells are good
  198. Does anyone else notice a slight reduction in (HP) when the A/C is on?
  199. Need new IMA Control Module and Error Codes?
  200. HCH2 - IMA battery reconditioning
  201. Out with a bang or a whimper?
  202. Hybrid 12 v battery not charging
  203. Passenger Airbag Recall bad repair job
  204. Most comfortable, best handling tires?
  205. 4 questions
  206. Sub Pack load test - 2007 Civic hybrid
  207. Well been aching to ask this, how do I undo the effects of octane mixing?
  208. HCF-2 fluid, do or not do? Old vs new HMMF fluid
  209. Balancing hybrid battery
  210. Hesitent clutch at an early start,
  211. Apart from changing the tranny fluid, how do I change tranny filter?
  212. valve adjustment, weight uneven?
  213. HCH 2 Screwed up my IMA battery
  214. Brake system
  215. Should I call the service manager?
  216. Grid charger prolong
  217. Water leak--from rear, apparenty
  218. Won't start, blinking, no OBD error codes
  219. New tire time - recommendations?"
  220. 2007 Civic Will not charge 12v no matter what
  221. Need a DIY or cheap grid charger/reconditioner solution
  222. Took OLD advice from early posts RE: IMA battery warranty & stick reconditioning :(
  223. What fuels work best? And is the new update for the civic worth it?
  224. HCH-II sudden IMA failure... Dealer or DIY?
  225. AC good only for 2 hours
  226. Civic Hybrid Battery
  227. CVT Transmission Problem - HELP!
  228. Valve adjustment, anyone done it?
  229. Which windshield wipers are correct?
  230. How much MPG does it cost to use AC?
  231. 12 volt battery won't charge after hybrid battery pack replacement
  232. new battery today...well almost
  233. CVT drops to low RPM; and slightly shaky at low speed. Normal?
  234. Where do we stand on AC refrigerant here?
  235. Ecopia MPG
  236. Improving the ride of an HCH2
  237. AC issues
  238. Lean burn mode activation?
  239. Bumblebee and Hybrid Revolt batteries
  240. Realistic MPG HCH2
  241. Autostop/Auto Climate Question
  242. Will these tires fit properly?
  243. AC clutch relay short problem
  244. HCHII, Getting Transmission replace, where to get Tranny Mount quickly
  245. SoCal dealers that'll replace IMA battery under warranty w/o IMA light on
  246. How do I actually get 50plus mpg?
  247. Cleaning the engine compartment
  248. Back-up Camera Install sotck Navi/Gps
  249. Anyone know if regular Civic bumper is the same?
  250. bought 2009 HCH - need advice
