Ima battery cell voltages
Old Oct 3, 2021 | 10:47 AM
nbinszky's Avatar
Default Ima battery cell voltages
After 1 night the cell voltages looks like this.
Yesterday they had 16-16.5v (checked in hds)
Morning the gauge shows empty, and after starting the car it starts to recharge ima bettery.
What do you think, should i try grid charging? Would it help?
Old Oct 4, 2021 | 08:25 AM
Default Re: Ima battery cell voltages
09-11 HCH2 battery is the worst hybrid battery ever made. 06-08 is the second worse ever made.
All resting voltages at all times should be almost identical. 16.0 to 16.5 is already a bad sign.
I can't quite read the voltages, but it looks like you have readings in the 13.xx to 15.xx range. Horrifying. 14.40V resting is EMPTY.
Primary failure mode is a complete loss of ability to hold charge. That's what I'm seeing.
Concerning grid charging, you have nothing to lose. Your battery is shot. Either it will work or it won't. If you do attempt grid charging, it is critically important that you force air through the pack.
Old Oct 4, 2021 | 11:50 PM
nbinszky's Avatar
And what is your opinion about chinese cells?
Old Oct 5, 2021 | 07:37 AM
They are inferior to the original Sanyo cells by a large margin.
Their warranty is completely meaningless.
Any purchase of chinese-made cells should be executed under the assumption that they will not last, nor will they have a meaningful warranty.
teachguy
Jan 10, 2021 12:11 AM
Jim K
May 9, 2020 09:42 AM
bharani
35
Dec 28, 2019 12:43 PM
Mcguiver
Jan 6, 2018 12:40 PM
schmidtj
Nov 10, 2007 11:47 PM
