Seat belt buckle
Old May 15, 2019 | 10:35 AM
Truomega's Avatar
Default Seat belt buckle
2006 Honda Civic hybrid
car got into a minor fender bender where the seat belts locked. So now I have the airbag light on. I replaced the passenger and driver side seat belts with good ones but the ABS light is still on. I’m assuming the latches that the seat belts click into also need to be replaced? Is there something I can do to reset the buckle part or do I need to replace them? Thanks
Old May 15, 2019 | 09:24 PM
Default Re: Seat belt buckle
You're assuming the ABS light and the seat belts are related. Do you know this?
Old May 16, 2019 | 06:41 AM
Truomega's Avatar
Sorry my mistake. It’s not the ABS light it’s the airbag light that’s on. I will edit the above to reflect that.
Old May 16, 2019 | 06:46 AM
That begs the question... is the airbag light linked to the seat belt light? I don't know, and I wouldn't assume it. IIRC from my Civic days, there was a fasten seat belt light at the top right at the "P" and "R" dots and the airbag light at the bottom right below the "L" dot. Is that the case?
If so, then you're likely dealing with an airbag issue as an impact is very likely to affect that system.
I recommend you disconnect your 12V battery for 5 minutes and then reconnect. See if the issue returns.
Old May 16, 2019 | 09:47 AM
Truomega's Avatar
Thanks for the response... this is what the dash looks like as of now (disregard the brake light as I have the E-brake on):
Old May 16, 2019 | 10:00 AM
Definitely the airbag light. Did you try the 12V disconnect?
Have you had the car checked for DTCs? If you have O'Reilly Auto Parts in your area, they use Bosch brand code readers and can usually pull up many codes other's can't.
Old May 16, 2019 | 10:54 AM
Truomega's Avatar
I did try to disco the 12v for at least an hour. Still came back up. The only safety device not changed was the seat belt latch. I looked at a picture of the latch and it has a lot of mechanisms to it. I’m assuming it’s a 1 time use item that requires to be replaced. I’m not certain about the mechanics of the buckle but below is a screen shot of the unit
Old May 16, 2019 | 11:01 AM
At this point running diagnostics is prudent.
Old May 16, 2019 | 11:38 AM
Truomega's Avatar
Will do. I’ll keep you posted on the outcome
Brian Tesoroni
Jul 2, 2014 08:02 PM
roseng
Jul 28, 2008 08:26 PM
seaford
Jan 8, 2008 02:01 PM
prg
Jul 18, 2007 07:04 AM
Island Mariner
Oct 19, 2006 05:24 PM
